Help on 350 LT1
Old Jan 25, 2013 | 08:06 PM
Martin.M92's Avatar
Help on 350 LT1
I am currently working on a restoration project for a 1949 Chevy pickup. I put in a 1987 350 LT1 from a camaro. The engine is not cranking when I try to start, I have the old camaro harness currently installed. What should I look into to get the engine started. Also should I take the fuel injection out and put in a carburetor. Would I need a circuit board for the transmission if I decide to do this?
Old Jan 25, 2013 | 08:17 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Help on 350 LT1
Lt1 efi engine didn't come out until 92 in y-body and 93 in f-body, is it a tpi ? is it cranking but not starting ?
Old Jan 25, 2013 | 08:31 PM
Martin.M92's Avatar
Re: Help on 350 LT1
Im sorry i guess it is a tpi im looking into some help for my dad, but it doesnt crank at all.
Old Jan 25, 2013 | 08:40 PM
thomas707's Avatar
Car: 1989 RS Camaro
Transmission: TH700R
Axle/Gears: No posi YET!
Re: Help on 350 LT1
Battery dead, starter wires corroded positive wires or grounding wires corroded. Check your fuses, ignition switch if you have one, dizzy cap, or bad ecu or maf.
Old Jan 25, 2013 | 08:41 PM
Engine: Lb9
Transmission: M20
Re: Help on 350 LT1
just to get the engine to crank over you need a wire going from the ignition switch to the starter s solenoid power from the positive cable from the battery to the starter and the engine block grounded from the battery negative cable.
Old Jan 25, 2013 | 08:44 PM
thomas707's Avatar
Car: 1989 RS Camaro
Re: Help on 350 LT1
What he said lol
Old Jan 25, 2013 | 08:50 PM
Martin.M92's Avatar
Re: Help on 350 LT1
ok ill try it out and post outcome
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
New2Chevy
Sep 28, 2015 12:35 AM
angel2794
Sep 8, 2015 06:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
