rapping/ticking noise??
Old Jan 25, 2013 | 09:18 PM
jrblu5201's Avatar
I have a 1984 camaro i just bought. Had a full exhaust put on it because the previous owner toke it to just headers. now that it has been completed i can hear a loud rapping/ticking noise that was a little intermittent coming from the enigine. the noise picks up speed with the rpms. After driving a few miles it became a constant noise.
I have no idea what to look at for this, what direction to start? Other than someone mentioned a wrist pin.
Any help would be aprreciated.
Old Jan 25, 2013 | 09:42 PM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Re: rapping/ticking noise??
Could be one of a few things..
1. Exhaust leak
2. Lifter Problem
3. Wrist Pin Issue
4. Rocker Problem
5. Rod knock
6. Injector
7. bent pushrod
Did it knock before it took it to that shop? If it didn't, I would suspect an exhaust leak but even that isn't 100% foolproof. Something could have gone wrong with the engine afterwards.
Old Jan 25, 2013 | 10:19 PM
jrblu5201's Avatar
I do not know if it did before the exhaust was put on i could not hear anything over it running straight headers. It was the shop that told.me about it before i payed they discovered it when they did their check for leaks in the new exhaust, which was just finished today
Old Jan 25, 2013 | 10:39 PM
ibmtech's Avatar
Car: 1987 IROC-Z
You could get an automotive stethoscope from a auto parts store fairly cheap and try to narrow down to see if it is external and where it is.
db057
Jan 10, 2020 08:55 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
Nighthawkf-117
Sep 24, 2015 02:47 PM
Randomtask2
Sep 7, 2015 05:06 PM
