Spark plug question
Old Jan 26, 2013 | 08:38 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Spark plug question
I was wondering what is a good spark plug to use in the newer vortec heads (906) since i believe that they use lithium plugs would it be alright to run these with my hsr vortec 355 or should i just stick with ac delco rt45s plugs an call it a day also will the lithium plug give a better spark then the ac delco rt45s
Old Jan 26, 2013 | 09:46 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: Spark plug question
I'm guessing you mean either iridium or platinum plugs. I'm not aware of anybody making a spark plug with lithium metal as it is very soft, hence it's use in grease. Anyway, any brand with a fine wire electrode in Ir or Pt will be an improvement over the Delcos in longevity if nothing else. While the plugs have some effect on the "quality" of the spark, that is more a function of your ignition system.
Old Jan 27, 2013 | 07:26 AM
Look up the part # used in a 98 Chevy truck with a 5.7.
Old Jan 27, 2013 | 07:40 AM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
I have always believed for gm vehicles, there is no better plug then the manafacture recommended ac delco plugs it came with. If you have added other parts to change the engines performance, I might step up the rapid fire ac delco's, but on a stock engine replace original with the same.
Old Jan 27, 2013 | 10:33 AM
Engine: LR4 4.8
lol sorry thats what i meant iridium ill just get the stock plugs for newer chevy trucks an try them out are these plugs shorter also since im running flow tech headers the last stock plugs i couldnt use cause they were rubbing up on the header
evilstuie
Feb 28, 2016 03:33 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
Bryan F
Aug 18, 2015 02:28 PM
