What is this part???
Old Jan 27, 2013 | 12:51 AM
spiffiestpengui's Avatar
Car: 1983 z28 and 3000gt twin turbo
Engine: 305 v8
Transmission: auto with b&m shifter
Axle/Gears: i dont know. they're stock
Hey can someone tell me what this part is? It is under the car kinda off center on the passenger side. In the engine compartment I found a rubber hose that is pretty badly cracked, and I followed it under the car to this part, since I had to get under it to change the oil anyways. The car is an 83' z28 305 5.0 carburetor 4 barrel. Mostly stock as far as I know. I want to replace that hose, but I think its probably a fuel line.
Attached Thumbnails What is this part???-img_20130123_135958.jpg   What is this part???-img_20130123_140001.jpg
Old Jan 27, 2013 | 01:28 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: What is this part???
Pic is very ordinary but from what you can see it looks like a fuel pump
Old Jan 27, 2013 | 06:44 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Difficult to see. A fuel pump would have three lines.
JamesC
Old Jan 27, 2013 | 07:29 AM
Yup, it's the fuel pump... you can see the bracket for the AIR pump above and to the right of it in the pics.
Old Jan 27, 2013 | 07:51 AM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Looks like both fuel lines and the rubber line need to be replaced. I can almost guarentee that as soon as you attempt to unscewing the fuel lines, They are going to twist the metal lines...
Old Jan 27, 2013 | 09:14 PM
Engine: 305 v8
Thanks guys for the info and the heads up on twisting the lines, I would have been pretty unhappy to get under there and twist them unexpectedly...I thought to get to the fuel pump you had to drop the rear end and gas tank and a bunch of other stuff?
Old Jan 27, 2013 | 09:29 PM
Only in cars with FI, or which otherwise have in-tank pumps.
The vast majority of carbed cars have always had pumps just like that one; block-mounted, driven by the cam.
Old Jan 30, 2013 | 07:04 AM
Pat Hall's Avatar
Yeah, consider yourself very lucky. Old-school fuel pumps are a DREAM to change compared to the in-tank ones on fuel injected 3rd gens!
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
