Bad Mixing Mobile 1 Synthetic with Lucas??
Old Jan 27, 2013 | 11:05 PM
calgutie's Avatar
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
Just wondering would it be bad if I were to mix Mobil1 High mileage 5w-30 Full Synthetic Oil with a bottle of Lucas Oil stabilizer??
Old Jan 28, 2013 | 05:35 AM
Re: Bad Mixing Mobile 1 Synthetic with Lucas??
Pretty much...
Synthetic oil doesn't need "stabilizing". Just use the right oil weight and be done with it. I'd suggest 10W-30, in Mobil1.
Old Jan 28, 2013 | 09:28 PM
joshc's Avatar
Car: 1986 Trans Am
Lucas is pretty much just thick tacky dino oil.
You will be degrading the Mobil1 by adding Lucas to it.
About the only time I would use Lucas in an anything is if it was on its last legs and smocking/knocking. It might buy a little more time.
Mobil1 High Mileage is great oil, you don't need to add anything to it.
Old Jan 29, 2013 | 02:46 PM
88FormulaF_Bomb's Avatar
Car: 1988 firebird formula 350
Axle/Gears: 2.77
lucas trans stop slip is the only lucas product ive ever needed in any car
Posted from Thirdgen.org App for Android
Old Jan 29, 2013 | 04:59 PM
Yenipenny's Avatar
Car: 92 RS Heritage
FWIW, Lucas makes stabilizer specifically for synthetic oils. It costs a couple of bucks more than the regular stuff.
Fronzizzle
Feb 9, 2017 09:31 AM
TheExaminer
Sep 28, 2015 02:28 PM
Stryker412
Sep 20, 2015 06:59 PM
cstrobel65
Sep 16, 2015 11:54 AM
Metalizer
Sep 13, 2015 12:56 PM
