Re-installing Air Conditioning
Old Feb 8, 2013 | 03:21 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
I have a 85 Camaro and the air conditioning was ripped out by previous owners. The brackets and all components are gone, the evaporator is still in the HVAC box, but the lines were simply cut off. I can get the entire system as well as a serpentine belt drive out of a wrecked car at the local wreckers very cheap.
The problem is that the car was originally a TPI 305 and was converted to carb. The engine harness was cut out and the only part that remains is the starter, alternator and distributor harness. The car works fine in that regard.
There is still a plug in the engine bay for the accumulator and the climate control switches inside the car are still there. the heat and all settings work fine.
What controlled the compressor, telling it to cycle on and off? Is it possible to re-install the air conditioning in the cars current electrical condition?
Old Feb 11, 2013 | 10:08 AM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Re: Re-installing Air Conditioning
Good question. The old owner ripped parts of it out, but I finished the job. Kind of thinking to put it back one day.
Vintageracer
Jan 10, 2020 05:33 PM
LittleFranks
Sep 17, 2015 12:22 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
jackhammer
Aug 15, 2015 10:04 PM
