why do some engined like nitrous so much more then others
Old Feb 8, 2013 | 10:21 PM
junk yard dog's Avatar
Car: 91 z-28
Engine: 350 camel hump heads 480 lift cam
Transmission: 700 r 4
I am trying to decide if my engine will benefit from say a hundred shot of nitrous? The engine is a 350 bored 60 over with flat top pistons it iron heads with a 64 cc chamber and 2.02 intake valves which should make about 10 to 1 compression the cam is like 480 lift and don't remember the duration carb is holly 650 double pumper. So what do you guys think nitrous or no nitrous? By the way it is not a forged rotating assembly. Thanks for any input you might have.
Old Feb 8, 2013 | 10:55 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: why do some engined like nitrous so much more then others
Is it a forged piston? what are your ring gaps?
Old Feb 9, 2013 | 08:06 AM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Almost ANY small block will benefit from a 100 shot!
Forged vs cast rotating assembly, including pistons, should not be a consideration for running just a 100 shot. IF you run decent fuel, have adequate fuel supply, run one range colder on plugs, get the mixture right, get the timing right, all will be fine. However, IF you don't get ALL of those right, then forged parts, pistons in particular, may buy you time, but they won't save you.
I wouldn't be concerned with the top ring gap on a factory build, but TTOP raises a good point since yours sounds to be a rebuild. What is your top ring gap? Hopefully you recorded that.
The fact that you've asked this question tells me the first thing you should do is pause for a few months and read up on running nitrous. When you truly understand how it works, all of the above becomes common sense. You'll find out there are multiple safegaurds available; it all depends on how complicated you want to get and how much your motor is worth.
If you respect the boundaries and understand how easy it is to step over those boundaries, I still maintain nitrous is the safest method available to add significant power to a motor.
I did my homework before I ever touched the stuff, have been running it since 2002, never had a failure with it, currently running a 100 shot on a heads/cam stock bottom LT1, putting 527 hp to the tires.
Old Feb 11, 2013 | 04:21 PM
s10sbc350's Avatar
Car: 91 Z28 camaro
Engine: L98 from 90-92 camaro
Of course it will benifit from nitrous but I think you meant to say if it will hurt it any, rite?
Old Feb 11, 2013 | 08:42 PM
Car: 91 z-28
Actually lmao i have seen some guys run it and not seen much gain maybe because it was timing was not just right or a fuel issue i am not sure and nobody else was positive either. That is why i asked that's what these boards are for right. Maybe someone had experienced problems and had success overcoming these hurdles. I knew my engine could hold fine to a small shot. Thanks for the input. Lets keep the input to positive or don't reply thanks.
Old Feb 11, 2013 | 09:26 PM
s10sbc350's Avatar
Car: 91 Z28 camaro
If someone doesnt benifit from a 100 shot then they either cant drive, or they shouldnt be messing with that stuff because Its all in the driver and it being set up correctly. Besides that no one has been negative yet lol but seriously i dont think motors are to picky when getting nitrous to answer your threads question, just sayng.
Old Feb 12, 2013 | 06:31 AM
86LG4Bird's Avatar
If somebody doesn't see much gain on a motor like yours with a 100 shot, then they're doing something very wrong that is not only hampering performance but likely causing damage. If they gave up, you don't want advice from those people If they stuck with it and figured out what they were doing wrong, whether or not they broke stuff along the way, then they may have something to contribute.
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
