help Id'ing engine block
Old Feb 9, 2013 | 09:15 PM
beav1993's Avatar
Car: 1986 trans am
Engine: 355 sbc
Transmission: t5 world class
Axle/Gears: 10 bolt posi 4:10 Richmond gears
Ok,ive got a gen2 sbc. Casting 14093638, suffix code says its from a 94 truck tbi. Its a 4 bolt main and had all roller provisions fully drilled and tapped but had flat tappet cam. I picked up a engine from a 88 Iroc camaro.same casting. Different suffix. This one says its from a 88 camaro( correct) had all roller equipment in engine. So I try to take it off and put it on my 94 engine. Everything went great till it got to the cam lock plate . The bolt holes for the plate are closer together on the 94 engine. But work fine on the 88. Am I dealing with some sort of hybrid block here or what? I'd like roller valvetrain but I don't know what to buy to match it up correctly! Thanks in advance guys.
Old Feb 9, 2013 | 09:44 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: help Id'ing engine block
Am I dealing with some sort of hybrid block here or what? .
There are two different bolt spacing for the cam retainer plate on roller engines
; early and late style.
You need the retainer plate with the bolt spacing to suit the year of block you are using
Roller cam thrust plate, (#10088128 ) with a 3.620" bolt pattern.
1991-2000 engines use (# 10168501 ) with 3.294" bolt pattern
http://www.jegs.com/p/Chevrolet-Perf...62118/10002/-1
Old Feb 9, 2013 | 09:58 PM
beav1993's Avatar
Car: 1986 trans am
Engine: 355 sbc
Thats a relief.I hate mixing and matching parts.I had no idea they had early and late rollers though I thought they were all the same. The link was much appreciated. Thanks a million!
Old Feb 9, 2013 | 10:04 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Other than the longer cam pin length ( for LTX engines ) the retainer plate is the only difference I know of between roller engines
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
Reddeath210
Oct 6, 2015 08:20 AM
lakeffect2
Aug 23, 2015 08:44 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
