Stroker kit???
Old Feb 13, 2013 | 09:24 AM
Jk_Under's Avatar
Car: 91 Camaro RS, 84 2.8 5speed
Engine: 305 5.0L
Transmission: Auto, 5 speed
Stroker kit???
I want to get a stroker kit for a 350 build im doing now, anyone know where to get a good stroked cam?
Old Feb 13, 2013 | 06:03 PM
Re: Stroker kit???
stroked cam
Not sure... please explain what that would be.
Old Feb 14, 2013 | 08:43 AM
Jk_Under's Avatar
Engine: 305 5.0L
Re: Stroker kit???
Well i was reading up on it, i want a stroker cam for a 350.
Old Feb 14, 2013 | 08:45 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Stroker kit???
A "stroker" uses the same cams as a "non-stroker".
Old Feb 14, 2013 | 09:18 AM
Jk_Under's Avatar
Engine: 305 5.0L
Re: Stroker kit???
Oh, then how do you make an engine a stroker?
Old Feb 14, 2013 | 09:29 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Stroker kit???
Buy some engine building books
Stroke refers to crankshaft swing length aka stroke. 350 crank moves piston 3.48". Stroker would just be a crank with longer length swing. Common is 3.75" which makes a 383 cubic inch motor.
Stroker cam doesnt really exist but maybe you heard about long stroker cranks needing special small base circle cams to clear the rod ends? In that case any cam company can make a cam on small base circle for clearance. However alot of rods these days are designed for longer strokes so may not need to worry about rod end to cam clearances.
Old Feb 14, 2013 | 09:36 AM
1killerolds's Avatar
Re: Stroker kit???
There's this awesome thing called Google. It lets you look things up and learn. making a stroker motor is basically changing the stroke of the crankshaft. take a 350 with 3.48" stroke and swap out the crank with one that has a longer stroke such as a 400 with a 3.75" stroke gives you an extra 33 cubes. many other things to consider such as rod length, piston compression height, etc. And some strokers use a small base circle cam to help clear the rod bolts or use a rod that has profiled rod bolt heads since the extra stroke will have clearance issues with the block.
Old Feb 15, 2013 | 01:12 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: Stroker kit???
wow, just wow.
Old Feb 15, 2013 | 03:20 PM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Re: Stroker kit???
You shouldn't be buying anything until you have a good understanding of how things work. Either that, or have someone who's more aquainted do things for you.
Old Feb 15, 2013 | 03:34 PM
88gunmetalgta's Avatar
Re: Stroker kit???
Actually, unless you're talking about chevy's in particular, strokers have a stroke length that longer than their bore diameter
To the OP, find a reputable engine builder, tell them what your plan on doing with the car, and let them build you an engine. Or face one hell of a learning curve.
Old Feb 15, 2013 | 04:41 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: Stroker kit???
That just refers to Over square or under square engines. The act of "stroking" increases crank throw to make piston move a greater distance to displace more volume
Old Feb 15, 2013 | 05:53 PM
Car: 1971 Camaro
Engine: 427
Re: Stroker kit???
Agreed.
Old Feb 18, 2013 | 09:54 AM
Jk_Under's Avatar
Engine: 305 5.0L
Re: Stroker kit???
I do know what im doing, Just some things im confused about. Thanks for the info, ive tried google just its easier to get better straightforward answers on here (since my car is a third gen of course). And delta i did plan on having a good proformance shop do the work, as for the motor itself, i can build that myself.
Old Feb 18, 2013 | 10:02 AM
Jk_Under's Avatar
Engine: 305 5.0L
Re: Stroker kit???
http://www.speedwaymotors.com/Scat-4...FQ6ynQodpDAAnw
Would this be a good one? it has 3.75" stroke
Old Feb 18, 2013 | 10:15 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Re: Stroker kit???
Hmmm....there are specific cams for stroker cranks and aftermarket rods in which you use a cam cut on a smaller base circle...no such thing as a "stroker cam" per se. No 3/4 race cams either...lol
Lots of stroker kits out there to convert your 350 into a 383 however!
Oh...and the crankshaft you posted will work great...on a 400 block.
EDIT: Doh!....I see the small base circle was already mentioned....carry on....
Old Feb 18, 2013 | 10:22 AM
Confuzed1's Avatar
Car: 83Z28 HO
Re: Stroker kit???
Here's an example of what you need:
http://www.jegs.com/i/Eagle/356/B13454L/10002/-1
Old Feb 20, 2013 | 10:12 AM
Jk_Under's Avatar
Engine: 305 5.0L
Re: Stroker kit???
And this is for a 350 correct?
Old Feb 20, 2013 | 12:06 PM
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
Re: Stroker kit???
Has eagle gotten better with their quality control? I would consider getting a kit from them if it weren't for every machine shop around me saying nasty things about their stuff when it comes to balancing issues. They all recommend Scat, but I'm always open for improvements.
Old Feb 20, 2013 | 07:04 PM
Confuzed1's Avatar
Car: 83Z28 HO
Re: Stroker kit???
I just posted that as an example of a stroker kit for the OP....
I run a Scat forged crank and Eagle sir rods. Never heard of Eagle QC issues from the machine shop I used to balance the assembly. I've seen people break most anything and any brand over the years...
And yes, it's a stroker kit for a sbc 350...
Old Feb 20, 2013 | 11:18 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Re: Stroker kit???
Go to jegs .com and just buy a stroker engine. You can buy a 383-396cu stroker engines complete short blocks from $3100-$3800.
Old Feb 22, 2013 | 10:25 AM
Jk_Under's Avatar
Engine: 305 5.0L
Re: Stroker kit???
Would this be a good engine kit to buy? 350 with 290 hp...
http://www.jegs.com/i/Chevrolet-Perf...529K3/10002/-1
I was thinking getting it bored .030 or .040 over and putting a 3.75" stroke cam. Would this be reasonably fast? And thanks for all the help getting this explained for me, it means a lot.
Old Feb 22, 2013 | 11:05 AM
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
Re: Stroker kit???
It's not the cam that makes it a stroker.... The cam does nothing to change this like we've already discussed. And no, that engine is a giant turd. I'd take a junkyard motor over one of those any day.
& Confuzed, I know. I asked because that's what you posted. Naturally speaking, you wouldn't post something like that if you thought it was a grenade waiting to go off.
junior419
Apr 7, 2025 11:35 AM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
