R&R a distributor/top dead center
Old Feb 15, 2013 | 06:00 PM
Kennycarlone's Avatar
Car: 91 RS T-Top
Engine: 305 High output TBI
Transmission: automatic 40LB...
Axle/Gears: Ten bolt
So I have a 1991 RS with the 305. I brought it to the shop and they moved my distributor around and moved my s.p. wires to the wrong spots. I believe I know how to put it back but just want some feedback before trying it.(feel free to correct me) First to find Top dead center you remove cylinder ones spark plug. second crank the engine until you get big push of air out of the cylinder one s.p. hole, then move the crank it over to* 0 degrees. third put the distributor back in (lined up where the dist. rotor is pointing at the #1 spot on the dist. cap) then put everything back together. * shouldnt it line up at 12 degrees? 0 sounds like it would be too retarded in timing. any links or other threads talking about this would help to, thank you in advance!
Old Feb 15, 2013 | 06:51 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: R&R a distributor/top dead center
When the engine is at about 12* the rotor will line up with the #1 terminal on the cap. At 0 the rotor will be nearly straight ahead.
Old Feb 15, 2013 | 07:02 PM
Car: 91 RS T-Top
Thank you very much for the correction. I was unsure because the videos ive seen kept saying 0 but put them on 12.
Old Feb 15, 2013 | 07:11 PM
If you've been watching videos on youtube you likely watched my video. I said 0 in my video because it's easier.
Old Feb 15, 2013 | 07:16 PM
Ed1LE
Sep 30, 2018 09:14 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
92projectcamaro
Sep 29, 2015 07:07 PM
raymondandretti
Sep 27, 2015 06:43 PM
