Need help with fuel question
Old Feb 15, 2013 | 09:07 PM
josh26's Avatar
Car: 1991 z28 t top
Engine: 406 dead, now 383hsr
Transmission: t5/ saving for tko
Axle/Gears: 373
I recently switched to HSR. Now I dont have fuel going through the regulator.
Have kibran adj regulator(which is brand new) walbro 255 fuel pump.
Not sure what the problem is. Any help wouod be great
Old Feb 15, 2013 | 09:50 PM
88formula305tpi's Avatar
Car: 1988 Firebird Formula WS6
Engine: 305 tpi lb9
Transmission: 5 speed
Axle/Gears: 3.45
Re: Need help with fuel question
sounds like a faulty regulator, i dont think you can install the diaphram wrong. did you try adjusting it?
Old Feb 15, 2013 | 09:53 PM
josh26's Avatar
Car: 1991 z28 t top
Axle/Gears: 373
Thats what I tthought too. Thats why I replaced the original holley one .and still have the same problem.
Old Feb 16, 2013 | 09:16 AM
Thats why I replaced ... and still have the same problem
This is usually a pretty reliable sign then, that the thing you replaced, (a) wasn't bad, and (b) isn't the problem.
If you take the regulator off and turn on the pump, does fuel come out?
What's the fuel pressure? The pump might not have enough cajones to get up enough pressure for the regulator to even have anything to regulate.
Old Feb 16, 2013 | 09:26 AM
josh26's Avatar
Car: 1991 z28 t top
Axle/Gears: 373
Yes when I take off the reg gas does come out of the fuel line . The fuel pump worked good until I swaped intakes last week .what kind pressure would you see going from the fuel line with no reg hooked up
Old Feb 16, 2013 | 06:57 PM
Engine: 305 tpi lb9
Axle/Gears: 3.45
I believe depending on your pump you could see as much as 90 psi before the regulator. I have a hard time thinking it could be anything other than the regulator since you say you have fuel to it and its not getting thru. only thing i can see go wrong would be maybe something with the diaphram is incorrect or there is a complete blockage there. I am going to be changing mine soon so am curious as to what the problem could be. never seen this before.
Old Feb 16, 2013 | 07:01 PM
Engine: 305 tpi lb9
Axle/Gears: 3.45
or as sofakingdom mentioned it may be possible to have very low pressure therefore not enough to make it thru the regulator. i would try to rig up a fp guage at the supply line and see if the pump took a dump.
Old Feb 16, 2013 | 07:03 PM
josh26's Avatar
Car: 1991 z28 t top
Axle/Gears: 373
Today I took the reg off and hit with the air hose and it does work so I think my fuel pump went bad I only have a little stream of fuel straight out the fuel line . So i ordered a new one tonight will let you know and thanks for all the help
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
fasteddi
Sep 2, 2015 10:29 AM
redmaroz
Aug 16, 2015 11:40 PM
