Spark Plug question
Old Feb 19, 2013 | 07:36 PM
hdis2002's Avatar
Car: 87 IROC Z
Engine: 5.7
Spark Plug question
I'm in the process of replacing the head gaskets on my L98. I figured I would replace the spark plugs while I've got everything apart. I have trick flow aluminum heads, btw. The plugs currently in use are Autolite 104. Just out of curiosity, I looked up what plugs are supposed to be in this engine and those plugs aren't even close. They have a .708 reach where stock is .460. Considering all of the things I've found screwed up on this car, I guess I shouldn't be surprised if these are the wrong plugs. What plugs do you guys recommend?
Steve
Old Feb 21, 2013 | 09:21 PM
krackle82's Avatar
Re: Spark Plug question
Those might not exactly be ""wrong". If the .708 reach isnt interfering with anything, that can be a plus. As long as they are the right heat range, (I say) you can roll with it.
http://aftermarket.federalmogul.com/...ce%20Chart.pdf
Old Feb 21, 2013 | 09:24 PM
Damon's Avatar
Aftermarket heads usually take different plugs than stock heads, especially aftermarket aluminum heads. You probably have the right plugs in there already. Thread reach is NOT something you want to get wrong in selecting plugs.
Call TrickFlow and ask them what plugs are recommended with those heads..... and use them.
Old Feb 21, 2013 | 09:45 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
I saw a stock 4.3 had too long thread reach. The valve got so hot the spring tension tried to pull the valve out of the combustion chamber...was ugly
evilstuie
Feb 28, 2016 03:33 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
Bryan F
Aug 18, 2015 02:28 PM
