may change my 350 build
Old Feb 19, 2013 | 10:15 PM
iroczjoe's Avatar
Car: 1987 iroc z
Engine: 305 tpi for now
Axle/Gears: 3:24
i built a carb 350 for my 87 iroc. i still havent put it in yet. mid 70's 350 601 heads 58 cc 2.02 1.94 valves, ported and polished. stock pistons , cam is .218 @ .50 .450 lift. 274 dur. 106 lobe seperation. .025 deck. .015 head gasket. edelbrock 650, generic aluminum dual plane. long tube headers....originally i was going to put it in with the stock 700r4 and stock converter since manufacturer said it would work. my goal is to run no slower then 12.80. so im changing a few things. i already pulled the heads back off to remove the stock pistons. im putting in + 6cc hyperuetic flat tops. 2500 lockup stall, scrap the fresh machined 601's for some vortecs with 2.02 1.94 valves and matching dual plane. do you guys think ill reach my 12.80 goal with this build...
Old Feb 19, 2013 | 10:54 PM
1gary's Avatar
Re: may change my 350 build
Joe-you should aleast dial-bore check the bores and hone them if they check ok.
Old Feb 20, 2013 | 03:01 AM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
I'm confused about your valve diameters but 12.8 should be easy with the right supporting mods.
Old Feb 20, 2013 | 03:38 AM
iroczjoe's Avatar
Car: 1987 iroc z
Axle/Gears: 3:24
I keep saying 1.94 i mean 1.60 thanks for the responses
Old Feb 20, 2013 | 09:59 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
You're going to need a good quality distributor that you feel comfortable tuning.
Old Feb 20, 2013 | 07:00 PM
iroczjoe's Avatar
Car: 1987 iroc z
Axle/Gears: 3:24
i was going to go with the pro-comp H E I distributor vac advance. i guess thats a good distributor. I honed the engine when i but it together b4 so its good, thanks every one for advice
Jake_92RS
Jan 28, 2020 10:37 PM
Reborn756
Sep 4, 2015 03:42 AM
crazynights
Aug 21, 2015 06:53 AM
Out-Cast
Aug 17, 2015 10:57 AM
sreZ28
Aug 14, 2015 07:48 PM
