differential pressure sensor help
Old Feb 20, 2013 | 09:04 PM
Avalosz28's Avatar
Car: camaro z28 1984
so i got code 32 on the carb model and it means differential pressure sensor is bad but i dont know where that is
Old Feb 20, 2013 | 09:18 PM
ex-x-fire's Avatar
Re: differential pressure sensor help
Look for a sensor that looks like a map sensor, instead of a vacuum hose it'll have a foam cover over the port. It should be on the firewall or around the heater & a/c components.
Old Feb 20, 2013 | 10:36 PM
Avalosz28's Avatar
yay thanks for the help so much figured it out check engine is gone!!!
9192camaro
16
Feb 3, 2019 12:21 AM
EduardoRonaldo7
Sep 8, 2015 01:28 PM
mdtoren
Aug 23, 2015 12:52 PM
R3500
Aug 17, 2015 12:16 PM
mdtoren
Aug 16, 2015 05:45 PM
