350 block
Old Feb 21, 2013 | 08:15 PM
tcrisp's Avatar
Car: 1989 camaro iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 323
350 block
just got a 350 1 piece long block for 100.00. how do i need to build it carb , tpi tell me what you think ?
Old Feb 21, 2013 | 08:45 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 350 block
You can build it however you want. What do you want to do with it, and what are you comfortable working with?
Old Feb 24, 2013 | 01:45 PM
D_Smith87's Avatar
Car: 1987 Camaro Iroc Z28
Engine: comp xr288 /budget aluminums
Transmission: TH350
Axle/Gears: 9-bolt BW 3.42 w/posi
Re: 350 block
really depends on what you want to do, u could stick all your 305 tpi setup on it, and stock cam unless u want to get everything reprommed and what not something i gave up a long time ago on my car, or get a healthy roller cam for that 1 piece block, with some decent heads and a rotating assembly out of another motor, if that didnt come with one or invest into a durable rotating assembly with stronger rods, steel crank, and hyper pistons, and have the capabilities of throwing over 500 horse at it, what kinda hp and tq numbers are u looking for? hop it up too much ur gonna need a stall converter, what trans do u have? never had luck with anyone i know going carb and retaining the 700-r4
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
Reborn756
Sep 4, 2015 03:42 AM
Eric-86sc
Aug 24, 2015 09:01 PM
BBSDesigns
Aug 11, 2015 07:39 PM
