are the 87 tuned port 350 motors interference motors? trying to set my timing but im scared ill hurt the engine
TTOP350
close
- Join DateOct 2001
- LocationIl
- iTrader Positive Feedback100
- iTrader Feedback Score(9)
- Car1989-92 FORMULA350 305 92 Hawkclone
- Engine4++,350 & 305 CIs
- Transmission700R4 4800 vig 18th700R4 t56 ZF6 T5
- Axle/Gears3.70 9"ford alum chunk,dana44,9bolt
- Liked:1,141 Times in 747 Posts
Um. Are you playing with the timing chain or just setting the timing by moving the distributor?
the timing is advanced and i dont want it like that so probably the distributor hopefully. i really dont wanna get into the chain
skirkland1980
close
Adjusting ignition timing will not effect valve to piston clearance.
TTOP350
close
- Join DateOct 2001
- LocationIl
Set the timing to the proper spec, unless you have some mods and/or want to go a bit faster.
The dizzy timing won't mess with the valve/ piston clearance
