need help please
Old Mar 3, 2013 | 09:39 AM
josh26's Avatar
Car: 1991 z28 t top
Engine: 406 dead, now 383hsr
Transmission: t5/ saving for tko
Axle/Gears: 373
need help please
I will start with what i did. I installed hsr in my 91 camaro. After the install the car wont start. Ihave spark I have fuel to the regulator.nothing coming. Through the regulator.
I jave replaced the fuel pump, fuel filter and the regulator.
Any help would be great
Old Mar 3, 2013 | 11:49 AM
ex-x-fire's Avatar
Re: need help please
Do you hear the pump run? A new pump won't run unless it has power & ground.
Did you pressure test the fuel system? I don't understand "I have fuel to regulator. Nothing coming up". The pump feeds the fuel rail & regulator at the same time.
Heres a basic diagram, the test port should be where the injectors are in the picture.
Old Mar 3, 2013 | 11:53 AM
josh26's Avatar
Car: 1991 z28 t top
Axle/Gears: 373
Yes I hear the pump running. I didn't pressure test the fuel system. I have gas to the regulator it just seems that I dont have enough pressure to open the regulator.
Old Mar 3, 2013 | 11:55 AM
ex-x-fire's Avatar
The reg. is after the fuel rail.
Old Mar 3, 2013 | 11:59 AM
josh26's Avatar
Car: 1991 z28 t top
Axle/Gears: 373
I am using the holley fuel rail. With holley stealth ram. Were would the regulator go to the supply or the return
Old Mar 3, 2013 | 12:15 PM
ex-x-fire's Avatar
Its where the return line starts.
Old Mar 3, 2013 | 12:22 PM
josh26's Avatar
Car: 1991 z28 t top
Axle/Gears: 373
Hey thank you so much for the help
