TPI speed density bogging (with video) please help!!!
Old Mar 3, 2013 | 04:02 PM
Chris_89rs's Avatar
Car: 89 Camaro R.S.
Engine: LB9 5.0 (lt1 cam)full exhaust..
Transmission: WC T-5 pro5.0 shifter zoom S/s
Axle/Gears: 9 bolt, 3.27's
The fuel will stay at. 30-35 and then drop to 20 or less
Old Mar 3, 2013 | 06:42 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: TPI speed density bogging (with video) please help!!!
Bad fuel filter?
Bad fuel pump?
Did you by chance have the flexible fuel lines off in the engine compartment? Are the properly installed?
Old Mar 3, 2013 | 06:48 PM
Chris_89rs's Avatar
Car: 89 Camaro R.S.
yes I have the tpi flex fuel lines, yes they are tight and it only does this when hot?
i have checked and tested everything else map,tps,injectors hot and cold new dizzy etc... just tested the fuel pressure today and got this ..???? fuel pump?? I did replace the pump with a china 255 of ebay but the pump sat for over a year and then went in... possibly a bad pump???
Old Mar 3, 2013 | 08:01 PM
TTOP350's Avatar
Bad pump or your fuel filter is plugged.
Are the fuel flex lines crossed in the engine compartment?
Grab a new pump from here http://www.racetronix.com/
Old Mar 3, 2013 | 08:19 PM
Chris_89rs's Avatar
Car: 89 Camaro R.S.
Grap a new pump from here http://www.racetronix.com/
what do you mean crossed??
I don't think one would reach because of the different length of the hoses and fuel and return line...
so this would be a bad pump??
I will change the filter and have my tank cleaned also I've dropped the tank twice and will not be doing it a third time lol 100 ain't bad for labor just gotta buy a pump
thanks for the quick response and also for taking the time to look at my post I appreciate it
Steve78LT
Feb 24, 2016 12:15 AM
GouldyGTR
Aug 21, 2015 10:43 PM
Out-Cast
Aug 17, 2015 10:57 AM
Sanjay
Aug 12, 2015 03:41 PM
86Base
Aug 8, 2015 01:34 PM
