Headers
Old Mar 8, 2013 | 12:56 PM
wishoradream's Avatar
Car: 1982 Z28
Engine: 388 SBC
Transmission: TH350 Lockup
Headers
http://www.jegs.com/i/Hedman/500/68470/10002/-1
Would these be worth picking up? I have heard pretty good things about hedmans, just wanted y'alls opinion
Old Mar 8, 2013 | 02:36 PM
rockstarr4's Avatar
Car: '84 Camaro - 2010 Surf Blue
Engine: 305 - 4 bbl Holley
Transmission: WC T5
Axle/Gears: 3.08
Re: Headers
I have the "Elite" version of these and they fit very nicely and don't rattle against anything. You will want to also purchase the companion Hedman Y-pipe as the headers will not fitup to the stock Y-pipe. Hedman has much better Y-pipe design with smooth mandrel bent curves.
The hardest part about installing them will be removing the old rusted exhaust bolts. You will also have to remove the driver side motor mount connection bolt and jack the engine up slightly to get the header past the steering column shaft. This is pretty easy, but remember to remove the distributer cap so it doesn't come into contact with the firewall when the engine moves up.
Old Mar 8, 2013 | 03:34 PM
Car: 1982 Z28
Engine: 388 SBC
Re: Headers
Phew.... that drivers side motor mount was a pain in the *** to get on there, Maybe I can just loosen the bolts on the engine part, and jack it up a little? Thanks for the reply, and luckily the exhaust bolts are off, it's not the stock engine, just an 86 350 out of a chevy custom deluxe
Old Mar 8, 2013 | 03:48 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Headers
Don't unbolt the mounts, just take the cross bolt out.
Old Mar 8, 2013 | 04:20 PM
rockstarr4's Avatar
Transmission: WC T5
Axle/Gears: 3.08
Re: Headers
Ditto, just take out the crossbolt.
Old Mar 8, 2013 | 06:44 PM
Car: 1982 Z28
Engine: 388 SBC
Re: Headers
I was having an issue with the cross bolt lining up, so I had to loosen the mount from the engine, to get it to set right, and retorque them, is what I meant.
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
