Whats a good timing chain and gear
Car: White 84 z28
Engine: Chevy 350
Axle/Gears: Posi and?
What is a decent quality chain and gear to buy? It is a double roller setup and the crank is a one key
Posted from Thirdgen.org App for Android
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: Whats a good timing chain and gear
My choice was Cloyes.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
The lowest-cost sets I've found that don't stretch are the Cloyes Street Rollers. Anything cheaper will stretch , so even if you degree the cam now, in 3 months you could re-degree it and you would find it several degrees retarded ( late ).
