Still cant get l98 motor started? Please help
Old Mar 11, 2013 | 12:55 AM
  #51
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Still cant get l98 motor started? Please help
After the injector wires hook together on each side of the engine back bye the bulk head cut the pink/black wires run them each to a 3amp fuse. One the other side of the fuses hook them to ignition switched power if you can't seem to trace the wires to do the repair correctly. If you run the wires through the bulk head make sure they are insulated going through a existing gromemet or drill a hole and instal a new grommet.
Old Mar 11, 2013 | 01:02 AM
  #52
s10sbc350's Avatar
Car: 91 Z28 camaro
Engine: L98 from 90-92 camaro
Ok now i understood this lol i think. so i install a fuse inline where each injector bank is at then take a wire and go from the fuse to the ignition switched power whch is the ignition switch that we were talking about earlier rite the one on the steering column? Also what do i buy tommoro other then a fuse block to make this happen, i already have speaker wire thats like 8gauge or 16 gauge i forget which.
Old Mar 11, 2013 | 01:08 AM
  #53
Engine: Lb9
Transmission: M20
You may have some empty spots in your fused box that are accessory power that you could jumper to the ato fuse block. Soldering and shrink tubing the connections under the hood is a better method. 16 gauge txl would be the wire to use.
Old Mar 11, 2013 | 01:17 AM
  #54
s10sbc350's Avatar
Car: 91 Z28 camaro
Wait why would i jump a empty fuse spot in my box to my fuse block? Also whats the ignition power accesory switch that connects after the inline, is it the ignition switch, or the igniton fuse spot in my fuse box that your talking about.
Old Mar 11, 2013 | 01:29 AM
  #55
Engine: Lb9
Transmission: M20
Unless you want a chance of a high parasitic draw you wouldn't want to feed them directly from a direct battery source.
Old Mar 11, 2013 | 01:38 AM
  #56
s10sbc350's Avatar
Car: 91 Z28 camaro
I dont get it so what is the ignition power accesorry thing you were teling me to hook the wires up to
Old Mar 11, 2013 | 01:41 AM
  #57
Engine: Lb9
Transmission: M20
Hook it up to a location where you have power when you turn the key to the accessory position, the run position and the crank position but now power. When the key is turned off.
Old Mar 11, 2013 | 01:47 AM
  #58
s10sbc350's Avatar
Car: 91 Z28 camaro
LOL thats what the ignition fuse slot does. Also its basicaly just a remote wire like what youd have on your stereo, so can i buy the fuse block at a store like autozone napa o'rielys or something?
Old Mar 11, 2013 | 01:50 AM
  #59
Engine: Lb9
Transmission: M20
Yup
Old Mar 11, 2013 | 01:57 AM
  #60
s10sbc350's Avatar
Car: 91 Z28 camaro
Oh ok im going to get one tommoro
Old Mar 11, 2013 | 02:07 AM
  #61
s10sbc350's Avatar
Car: 91 Z28 camaro
http://www.oreillyauto.com/site/c/de...ord=fuse+block would anything like this work fine? Also will a inline fuse holder work because i have one already if so?
Old Mar 11, 2013 | 10:45 AM
  #62
s10sbc350's Avatar
Car: 91 Z28 camaro
??? So before i go get a few will something like the inline fuse holder in the link work fine? Oh and will 4 of these be enough
Old Mar 11, 2013 | 11:01 AM
  #63
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
See this where it says INJ1 and INJ2 ? Y would u need 4?
Originally Posted by tunedperformanc
Old Mar 11, 2013 | 11:26 AM
  #64
s10sbc350's Avatar
Car: 91 Z28 camaro
I thought tuned p said that i should do 2 threeamp fuses for half the injectors, then two 3amp fuses for the other half rite? Im sorry but i just woke up but also how do i connect the 1 or 2 in line fuses to the 4 injectors that need power then the other 4? By running wire from inj 1,3,5,7 then to the fuse or how would it work
Old Mar 11, 2013 | 11:31 AM
  #65
s10sbc350's Avatar
Car: 91 Z28 camaro
Oh i see now lol so i just connect one side of fuse to the 12olt remote spot, then i run wires from the other side of fuse and branch off to each injectors power wire rite?
Old Mar 11, 2013 | 11:38 AM
  #66
Engine: Lb9
Transmission: M20
You have it right but the power going to your new fuse box will be just when you turn the key on and during crank and run. Like a car stereo you don't want it on when your not around it will drain down your battery.
Old Mar 11, 2013 | 12:06 PM
  #67
s10sbc350's Avatar
Car: 91 Z28 camaro
Alright im going to go get the fuse holder here in awhile. I guess i need to get 2 litte 3 amp fuses aswell since i have almost all but that size lol
Old Mar 11, 2013 | 12:19 PM
  #68
s10sbc350's Avatar
Car: 91 Z28 camaro
Oh last question real quick. So what order are the injectors in if 1,3,5,7 need to go to 1 fuse? Are they basicaly on the driver side and the 2,4,6,8 are on the other side? And pink/black wire is injectors power wire you said rite?
Old Mar 11, 2013 | 01:50 PM
  #69
s10sbc350's Avatar
Car: 91 Z28 camaro
??? ^^ I just need to know before i hook it all up
Old Mar 11, 2013 | 01:55 PM
  #70
Engine: Lb9
Transmission: M20
Yes the pink and black is the power wire on each side they all tie together into 1 wire in the harness just after the intake on the rear. It doesn't matter what side goes to witch fuse.
Old Mar 11, 2013 | 01:57 PM
  #71
TTOP350's Avatar
SEARCH
firing order of a SBC
Old Mar 11, 2013 | 02:09 PM
  #72
Engine: Lb9
Transmission: M20
Originally Posted by TTOP350
SEARCH
the injectors are batch
Old Mar 11, 2013 | 02:17 PM
  #73
s10sbc350's Avatar
Car: 91 Z28 camaro
Alright and im going to have to use like a 10amp fuse since they didnt have any 3amp ones, but it shouldnt matter rite?
Old Mar 11, 2013 | 02:18 PM
  #74
Engine: Lb9
Transmission: M20
It will work just takes more amperage to blow
Old Mar 11, 2013 | 02:25 PM
  #75
TTOP350's Avatar
That will tell him where the cyls numbers are and most important, how to look for info without someone holding his hand.
Old Mar 11, 2013 | 02:26 PM
  #76
Engine: Lb9
Transmission: M20
I confuse easily lol
Old Mar 11, 2013 | 02:28 PM
  #77
s10sbc350's Avatar
Car: 91 Z28 camaro
Ok so the driver sde injectors wires are solid green, and orange with black stripe s is the one with stripe power? The pass side has pink/blk wire though.
Also the injectors power wires dont go into one wire they all 4 split from a 1inch wire loom near firwall to a big 3inch loom then go into the firewall with about 70wires, so im goin to have to splice them all together somehow then run 1 wire to the fuse will that be fine?
Old Mar 11, 2013 | 02:29 PM
  #78
s10sbc350's Avatar
Car: 91 Z28 camaro
Firing order? for what
Old Mar 11, 2013 | 02:46 PM
  #79
s10sbc350's Avatar
Car: 91 Z28 camaro
So will that be fine ^^ and the orange and blk wire is the power one rite?
Old Mar 11, 2013 | 04:28 PM
  #80
Engine: Lb9
Transmission: M20
Orange/ black should be the other power just double check your ecm pin d15 should be the light blue and d16 light green.
Old Mar 11, 2013 | 04:32 PM
  #81
s10sbc350's Avatar
Car: 91 Z28 camaro
I got half done and its lighting the test light now, yay. I just have to do the other side now, lol im getting a headache from bitting off all these wire ends but im so close so ill let yall know here soon, or in an hour if it works, lol
Old Mar 11, 2013 | 04:50 PM
  #82
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
normally when someone does a conversion with the factory harness, they keep the FI fuse box.
usually its near the ECM & it looks like this,
Attached Thumbnails Still cant get l98 motor started? Please help-image0104.jpg
Old Mar 11, 2013 | 06:05 PM
  #83
s10sbc350's Avatar
Car: 91 Z28 camaro
Ok so its still not running it will start and run for a few secnds like 4-5 then it dies like before, and it only does it with gas or starting fluid threw tb. So The injrctor plugs are getting power though now, on both sides of the plug it lightes up. So i dont get it why wont it work
Old Mar 11, 2013 | 06:09 PM
  #84
Engine: Lb9
Transmission: M20
did you ever check the 3 power wires going to the ecm ?b1,c16, a6 with the key on.
Old Mar 11, 2013 | 06:33 PM
  #85
s10sbc350's Avatar
Car: 91 Z28 camaro
I jst tried to check them and the probe wont fit in the plug holes, but what could i check over since it should be running rite? And i mean other then those three ports since they arent checkable with my probe
Old Mar 11, 2013 | 06:40 PM
  #86
TTOP350's Avatar
Use a small paperclip as a jumper to backprobe your ECM.
Old Mar 11, 2013 | 06:41 PM
  #87
s10sbc350's Avatar
Car: 91 Z28 camaro
Ok so basicaly its still a fuel issue rite, because it starts with gas dwn throttle body only, but culd the starter not be spinnign fast enough and the starter be bad,or what are the possibilities.
Old Mar 11, 2013 | 06:42 PM
  #88
s10sbc350's Avatar
Car: 91 Z28 camaro
Alright ill go do it when i knw a few more things to check.
Old Mar 11, 2013 | 07:25 PM
  #89
s10sbc350's Avatar
Car: 91 Z28 camaro
what about the tps
Old Mar 11, 2013 | 08:34 PM
  #90
s10sbc350's Avatar
Car: 91 Z28 camaro
??? Im getting pretty frustrated with this POS and am about to buy some c4 and blow this thing up. Could the tps sensor be bad and the ecm think its it wot mode and clear the injectors
Old Mar 11, 2013 | 08:40 PM
  #91
Engine: Lb9
Transmission: M20
C4 is a good body style of vette
Old Mar 11, 2013 | 08:53 PM
  #92
TTOP350's Avatar
Ya know, a lot of things could be wrong with this project.
If you would test the things we tell you to and how we tell you to, instead of jumping around all the time you would be driving this thing by now.
Old Mar 11, 2013 | 09:16 PM
  #93
s10sbc350's Avatar
Car: 91 Z28 camaro
Lol not the c4 vette the c4 that goes kaboom! lol so what do you want me to test next just give me a list or something id like to know a few things that it could be and how to test them, and trust me i have been waiting over a month to drive it and im pretty close to getting it running, i think
Old Mar 11, 2013 | 09:45 PM
  #94
Engine: Lb9
Transmission: M20
Di you get power with the key on to the ecm pins I posted to check
Old Mar 11, 2013 | 10:07 PM
  #95
s10sbc350's Avatar
Car: 91 Z28 camaro
Alright i just checked the port b, and c on the throttle positioning sensor, and i had my meter on ohms, then tried volts and i got no readings both times, so is it bad, or did i not check it rite. The key was on also and i grounded the black probe good.
Old Mar 11, 2013 | 10:09 PM
  #96
s10sbc350's Avatar
Car: 91 Z28 camaro
Also i just tried checking with a small nail since i have no paper clips, but the probe on test lite was still smaller and not small enough, so ill have to get some paper clips, or find some sodering wire to check the 3 ports
Old Mar 11, 2013 | 10:29 PM
  #97
Engine: Lb9
Transmission: M20
Ohms is a measure of resistance you would need to check with the key on the blue wire of the tps. It would be .54v if it goes to 4 or higher the ecm will go into clean flood mode and stop injector pulse.
Old Mar 11, 2013 | 10:35 PM
  #98
s10sbc350's Avatar
Car: 91 Z28 camaro
Alright i just checked those 3 ports in ecm harness and the test light didnt light for any of them, and i scraped back some wire on all three then touched the bare wire with test light, and it didnt light, with ignition on.
Also i tested the injectors with my meter and it read 12.50volts, and my test light still works aswell.
Old Mar 11, 2013 | 10:37 PM
  #99
Engine: Lb9
Transmission: M20
There's your problem
Old Mar 11, 2013 | 10:38 PM
  #100
s10sbc350's Avatar
Car: 91 Z28 camaro
I know thats exactly what i did, port b is the one your supposed to check and i checked all 3 and got nothing so im clueless as why it didnt show anything.
