High BLM at idle (160) - Normal at cruise (130+)
Old Mar 9, 2013 | 11:53 PM
scott2455's Avatar
Car: 89 Camaro IROC Z28
89 Camaro z28 w/ 5.7L
Been having issues with the engine running rich at idle (can smell unburnt fuel)
Hooked up Tunerpro RT and found that the BLM's hit 160 (cell 0) within 5 minutes of starting the engine.
O2 reads 300-700mv at idle but goes from 80-200 at 1200rpm.
BLM at 1200rpm is at 130-134, so normal.
  • I have used the carb cleaner method to search for vac leaks.
  • Replaced the pcv valve just in case (it only cost $3).
  • Fuel pressure is at 45psi at KOEO
Is the O2 reading normal? What else could cause this? Injectors?
At a loss here...
Azrael91966669
25
Jun 20, 2017 04:04 AM
CORV3TT3
Aug 23, 2015 11:26 AM
ezobens
Aug 19, 2015 10:29 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
