what sealant to use for fuel lines?
Old Mar 11, 2013 | 07:48 AM
pimpimusmaximus's Avatar
Car: 1984 Z28 T-TOP
Engine: 355 Lt1 w/Hotcam
Transmission: TH700R4
Axle/Gears: 3.73 4th gen limited slip
liquid teflon, rtv? Just wanna do it right. They are aftermarket pre-made hoses. refering to sealing threaded connections. Being an EFI fuel line and connecting billet fuel filter and adjustable pressure regulator. I want no leaks.
Old Mar 11, 2013 | 08:20 AM
BOTTLEDZ28's Avatar
Transmission: A4
Re: what sealant to use for fuel lines?
Do not use any type of sealant on the threads of the fuel lines on the car! The fittings on the end of the lines are a compression style fitting using an O ring to seal the line.
Fuel Injected engines require fuel pressure above 40 or so PSI on inlet side depending on application. You cannot or should I say should not use rubber hose s with hose clamps in place of the proper high pressure lines. If someone made you special hoses then please let us know exactly what type of fittings were put on the ends of the lines.
Old Mar 11, 2013 | 09:29 AM
Car: 1984 Z28 T-TOP
no they are jegs pre assembled fuel hose lines with -6an fittings. Mabye they have an O-ring inside them. Haven't even opened them yet.
Old Mar 11, 2013 | 10:23 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Post a picture of what you have.
Old Mar 11, 2013 | 10:50 AM
Car: 1984 Z28 T-TOP
please tell me how to post a pic. The only link I have needs a url to post.
Old Mar 11, 2013 | 11:20 AM
tomsaddy's Avatar
Car: 1987 GTA
Engine: TT LC9
Axle/Gears: 3.50
If it's a real -AN (37 deg) fitting or tapered pipe fitting you don't need anything. If you're worried about corrosion or seizing, you can use something like this:
http://www.aircraftspruce.com/catalo...lickkey=218206
Don't try to use sealant to fix a leaking connection, since there's likely a problem with the fittings at that point.
-Tom
Old Mar 11, 2013 | 03:49 PM
Car: 1984 Z28 T-TOP
my fuel pump, fuel hoses, fuel filter and one way flow valve are all -6 AN. I ordered them all that way to make the fit easier. Just thought there should be some sealant. Guess not thanks.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
