87 octane 100% gas vs 93 octane with ethanol
Car: 1986 z28
Engine: 350 hsr
Transmission: probuilt 700r4/edge 2800
Axle/Gears: stock 4th gen 3.23
I was wondering which one would yield better performance in my small block seeing as how I can get 100% gas in my town......I currently run the 93 with ethanol
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: 87 octane 100% gas vs 93 octane with ethanol
Depends on compression ratios and cam but i would feel confident in 93 oct over 87 for pure power.
If low compression deal then likely dont need 93 oct. Use least amount of octane as required to keep motor out of detonation with reasonable timing. Spark plug heat range and timing can bandaid too high comp for gas so you would want to look at exhaust temperatures and power output
There was a brief blurb here.
It may or may not interest you.
http://www.ccfbg.com/forum/viewtopic.php?f=1&t=14401
dbrochard
Oct 3, 2015 12:43 PM
