Do I need different pushrods?
Old Mar 15, 2013 | 07:29 PM
RWO3's Avatar
Car: '84 Camaro Sport Coupe
Engine: 355
Axle/Gears: 3.08
I want to put scorpion 1.5 ratio full roller rockers on my vortec 350. Can I reuse the stock pushrods or do I need to change lengths or something because of the new roller rockers?
Thanks.
Old Mar 15, 2013 | 09:14 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: Do I need different pushrods?
You'll have to mock it up. From my experience stock pushrods tend to be too long.
Old Mar 15, 2013 | 10:45 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Going from a stamped steel rocker to a roller rocker of the same ratio can usually reuse factory length pushrods however you never know how far the valve train geometry may be out even with stock pushrods. Stock rockers have a very wide ratio tolerance while aftermarket roller rockers are more precise.
It's always best to use a length checker to make sure the geometry is a close as possible. Technically, at half lift, the rocker should be 90* to the pushrod. This will make the smallest witness mark across the valve tip even if it isn't directly in the center of the valve tip.
A simple answer is yes you can but it's always better to make sure the geometry is correct.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
slowsi
Oct 18, 2015 08:49 PM
mfp189
Sep 27, 2015 09:25 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
