85 iroc-z intermittently runs bad
Car: 1985 iroc
Engine: 305 tpi
Axle/Gears: 273
5.0 tpi starts good and will run well at idle and all speeds until it is stopped and re started. Then it runs terrible,. injectors at 16 ohms, plugs dry,
no vacuum leaks, please help
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 85 iroc-z intermittently runs bad
It sounds like your ecm might be the cause of the issue. The 1226870 is the worst ecm for tpi.
http://www.ebay.com/itm/85-CHEVY-CORVETTE-ENGINE-ECM-SER-1226870-/140898384967?pt=Motors_Car_Truck_Parts_Accessories&hash=item20ce32bc47&vxp=mtr
