OK I know not another no start question..but yes
Ok heres the back ground on this car. I bought it knowing it didnt run but im pretty good at fixing cars as I do it for a living. It's a 1989 Firebird 2.6 I knew it had a VATS problem from the beginning as the factory key switch was on the dash (with no key). So I found a sitch and a new VATS controler and installed both (what a MFer). From there I checked the timing and replaced all the plugs wires cap rotor and checked the fuel pressure, all of things are within tolerance. So here we are right now, we have spark, fuel, and no secuity light, no codes and you guest it no start. My next move is comression testing, I have looked over all the hoses and electrical and can find nothing out of place...Im really losing it here please help.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: OK I know not another no start question..but yes
All the plugs are getting wet so I assume that the injectors are spraying...wether they are putting enough fuel in or not is a question...I have tried ether and no change
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
What test did you perform to confirm spark?
Car: 91 Bird
Engine: TPI 350
Transmission: 5-Speed
Axle/Gears: 2.77 posi
I would check the compression next also. make sure cam is timed to crank.
Correct timing plus fuel plus spark plus compression you should be getting something.
Injectors may not be spraying, could be dribbling fuel out. It needs to spray to get a good combustion.
92camaroJoe
Aug 13, 2015 06:07 AM
