car wont stay running
Old Mar 19, 2013 | 05:09 PM
z28guy134's Avatar
hey guys. im pretty new to this board. but i have an issue with my car it is a 1985 z28 its the original 305 and carb. i sprayed out the engine bay one day at the self serve car wash and fried the ecm so i replaced it and it ran for a few days pretty well and then i could get it to start but would ide for a little bit but die or if i pushed the gas it would die off too but i noticed one of my tail pipes was pushing out white smoke and was wondering if a cracked headgasket my bet the issue
thanks alot hope to hear some ideas
Old Mar 19, 2013 | 05:12 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: car wont stay running
have you pulled the distributor cap to check for moisture ?
Old Mar 19, 2013 | 05:20 PM
z28guy134's Avatar
it sat for a good 3 months before i figured out the ecm was bad and i disconnected all electronics and the distributor was dry as a bone
Old Mar 19, 2013 | 05:21 PM
z28guy134's Avatar
i made sure every thing was dry
Old Mar 19, 2013 | 05:22 PM
Engine: Lb9
Transmission: M20
how fresh is your fuel than ?
Old Mar 19, 2013 | 05:36 PM
z28guy134's Avatar
it was fres premium cause i filked it up when i drove it after i replaced the ecm
Old Mar 19, 2013 | 05:42 PM
Engine: Lb9
Transmission: M20
The white smoke is odd you can pull the plugs and look for evidence of a blown head gasket, do a leak down test or when the engine is cold remove the radiator cap and run the engine if its real bad you will see alot of bubbles after the thermostat opens.
Ghettobird52
Jul 5, 2024 11:18 PM
specialized
Jun 18, 2022 09:26 AM
Kaweh
Aug 9, 2015 02:54 PM
Sherpajames
Aug 7, 2015 06:56 PM
