new cap rotor ect.. no start?..
Old Mar 19, 2013 | 08:39 PM
Tyler1986's Avatar
So i recently did a dist cap rotor spark wire and plug replacement and coil *inside distributor not sure what it is sadly.. :/* and the car started fine before this..(1986 iroc-z27 camaro 305 4bbl carb)
Things i did not do that i should have...
Mark rotor position..
Replace wires 1 by 1...
Didnt check for TDC *have no clue how really.. to find #1.. just put it 2 away from the b+ terminal on the distributor.. and wired the rest clockwise as follows 18436572.
it will crank and make a pop/fart noise for a sec then keep on cranking.. battery is long dead by now u.u.. been fighting with this for a couple of days can anyone help me? >.<
Old Mar 19, 2013 | 08:45 PM
Bldgengineer's Avatar
Re: new cap rotor ect.. no start?..
sounds like its still not firing in the right order to me. had the same oroblem on my suburban when it accidently switched two of the wires.
Old Mar 20, 2013 | 09:03 PM
Tyler1986's Avatar
hmm i was told by 2 maintence guys at my work that i trust for technical advice cuz they are genius haha.. that its the ignition coil pack ontop of the distributor.. if the weather doesnt kick up as bad as its supposed to tomorrow ill pick one up and slap it in sunday on my day off.. and let yall know what happens.
Old Mar 20, 2013 | 09:20 PM
KMdoza7's Avatar
Car: 1989 IROC-Z28 Camaro
Engine: none
Transmission: T-56 W/ Spec 1 Clutch
Axle/Gears: 9 Bolt BW 3.27 Gears
your wires are not where they should be on the distributor. first off you want to be at TDC 1 compression stroke. so to do this your going to remove your #1 sparkplug then put in a paper towel inplace of the plug and crank your engine...slowly..once you hear air blowing out of the cylinder and the towel being thrown out..then go check if your timing tab and your harmonic balancer are lined up at the 0* mark..if its not then just rotate your engine with a 5/8ths deep socket until they do line up...now go check your rotor on your distributor thats where your #1 should be located on your cap...then just follow the rest of the firing order going clockwise...18436572
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
Winchester1094
Aug 18, 2015 10:23 AM
