Stop flywheel from turning
Old Mar 20, 2013 | 08:56 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
How do you stop a flywheel from turning while you torque the bolts?
Old Mar 20, 2013 | 09:46 AM
Westech's Avatar
Car: 1991 Camaro RS
Axle/Gears: 7.6" 3.73 yukon locker
Re: Stop flywheel from turning
There is a tool for that if you want to spend the money... google it. Flywheel wrench. OR just use a pry bar and get it in the starter head. yes you can do it with out busting stuff up.
What I do is use lock tight and hit the bolts with my 3/8 impact. Good to roll. But if you want to do it right try the pry bar or the wrench.
Old Mar 20, 2013 | 09:47 AM
midias's Avatar
I was told I can use a long bolt through the clutch bolt hole and brace it on the block. Is that extra bad advice?
Old Mar 20, 2013 | 09:49 AM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
I just used to put a long, thick screw driver through one of the outer holes and locked it onto some part of the engine block. Ok, I had a second pair of hands those days. Or rather, my assistant had a pair of hands for me
Ok, so you've got a flexplate for a manual clutch.
I guess its similar there.
Edit:
Dammit! Mixed the words around. Sorry. Still... should be the same for both!
apo_bailon15
Mar 28, 2016 05:20 AM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
Wade787b
Sep 29, 2015 01:15 PM
dibella989
Sep 1, 2015 04:12 PM
Trickskier
Aug 29, 2015 01:12 PM
