Hear range "tuning"?
Old Mar 20, 2013 | 08:01 PM
krackle82's Avatar
I heard someone once saying that if you use colder plugs in the middle 4 cylinders (3,4,5 and 6), idea being there are 2 exhaust ports right next to each other and these cylinders run hotter, and hotter plugs on the other 4, the engine will run more efficiently and smoother, changing some over looked engineering flukes. Anyone heard of his, or tried it?
Old Mar 20, 2013 | 08:07 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Hear range "tuning"?
There's a whole lot you can do for more power before you start trying that kind of stuff.
Old Mar 20, 2013 | 08:30 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Havent heard of that but kinda makes sense in theory but motors dont seem to have issues. On serious race stuff, guys will run coolant lines into the side of the head between exhaust ports to keep things cooler. I wouldnt mess with plug heat range by cylinder unless you knew exactly what each intake port was doing regarding air and fuel distribution. If you know what each cylinder is doing you shouldnt run into any issues like detonation/preignition or any reason why you would need different plugs per cylinder. Just my guess and experience with a few motors.
Old Mar 20, 2013 | 08:35 PM
krackle82's Avatar
I know installing a cam is a lot more cost and labor-effective, but this idea does work, right? And not so much for power gains, but for effeciency.
Old Mar 20, 2013 | 10:25 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
On a street engine you'd never see a difference.
Old Mar 20, 2013 | 10:41 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Spending countless hours on a dyno can find all kinds of small gains if small gains can win a race. For just about everyone else, you'll never notice a difference. Just install the coldest plug possible that doesn't foul up.
The proper heat range will show a slight bluing about half way down the ground strap. It's only easy to see on new plugs.
Old Mar 21, 2013 | 09:56 PM
krackle82's Avatar
Thanks for the input, guys. I didnt know if I'd see a difference or not, but I figured I'd ask. The Delco 43's in there now constantly look black, so I think Im gonna go up a range.
Old Mar 21, 2013 | 11:08 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Plugs are cheap. Standard copper plugs should be changed every few years anyway. Platinum plugs etc cost more but don't need to replaced as often. That's the only advantage to a platinum plug. They don't wear out as fast.
Old Mar 21, 2013 | 11:20 PM
bwiencek's Avatar
Car: 1984 TA - 17k orig miles
Engine: 355
Axle/Gears: 3.44 Dana 44 performance rear
If they're completely black then you're running way too rich.
Old Mar 22, 2013 | 04:38 PM
krackle82's Avatar
I generally change the plugs every spring. And they're not as black as I made them sound, they arent fouling out or anything. Just consistantly black, if you know what I mean. I should add, it's time for a tune up.
Old Mar 22, 2013 | 06:33 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Fouling will have deposit buildup on them because they are not hot enough to burn off the deposits. Soot is normally from running too rich but that can also be affected by timing. Adjusting the timing can change the fuel requirements.
When tuning especially on a dyno, timing is the first thing that needs to be determined. Every engine is different and no matter what else you do for tuning, the timing the engine wants will never change. Changing major component will change what the engine wants but not not tuning (jets, plug gap etc)
It's not uncommon to have different heat range plugs in an engine that has other issues. If you have leaking valve seals in one head, going up 1 heat range just in that head to help burn off the oil deposits will work until the seals can be replaced.
Old Mar 26, 2013 | 10:42 PM
krackle82's Avatar
Maybe a dumb question, but how do you determine what timing the engine wants?
Old Mar 26, 2013 | 11:44 PM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
Axle/Gears: 9 bolt posi 3:27
timing light
Old Mar 27, 2013 | 03:38 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Originally Posted by ksith
timing light
No. That is how you can SET the timing, NOT determine where to set it.
Old Mar 27, 2013 | 07:14 AM
AlkyIROC's Avatar
Car: 87 IROC L98
On a dyno. Timing is adjusted to where the engine makes the most power.
You can experiment on a dragstrip as well but it takes a lot longer. Timing is set where you make the most MPH. You make multiple passes adjusting only the timing until you can't make any more MPH then go on to other tuning.
Old Mar 27, 2013 | 11:34 AM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
apologies for my previous post. yes timing light is setting timing not determining. alky is right only way to really do it right is on a dyno. that and time
Old Mar 27, 2013 | 11:43 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Also can check plugs to verify timing mark on the ground strap is in the right position
Old Mar 29, 2013 | 04:59 PM
krackle82's Avatar
Awesome info. Thanks, gents!
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
Ed1LE
Sep 30, 2018 09:14 AM
Fanatic1074
Oct 2, 2015 03:47 PM
sjorgens
Oct 1, 2015 07:54 PM
