1988 Camaro 5.0 TPI Won't Start
Old Mar 21, 2013 | 03:37 PM
RocNRoll's Avatar
Car: 1988 IROC-Z
Axle/Gears: 3.08 POSI Rear
Hey guys,
I have an 88 Camaro that I have been driving for 4 months that won't start. When I bought the car, it would typically take longer than usual for the engine to turn over which I think is due to an old starter.
I have been working on my car all winter and let the battery drain because I've had the interior lights on the whole time (I know, not smart). I was getting ready to take the car out for a spin and it wont start now. There is just a very distinct clicking noise when I jump the car and turn the key over. When my camaro is connected to my daily driver when I jump it, the headlights come on strong as well as all of the interior lightning. When I turn the key over, the lights all dim and the clicking starts.
I just changed the lock cylinder because the old one was broken so I thought that may have something to do with it but it may just be a coincidence that the car doesn't start just after I changed that out.
My brother-in-law is a mechanic and said he is positive its the starter. He suggested I hit it with a hammer to loosen the solenoid but that hasn't been working. I have read a bunch of threads that suggest it could be a number of things, bad battery, poor cable connection, bad cables, etc. I firmly believe it is the starter or the battery. Based on your experience, what do you think it is?
Thanks guys
Old Mar 21, 2013 | 03:59 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: 1988 Camaro 5.0 TPI Won't Start
Originally Posted by RocNRoll
Hey guys,
Thanks guys
That's a classic bad battery. When you killed the battery by leaving the lights in you killed a cell in the battery. Pull it out and take it to Autozone and have it checked, but I'm 99% sure that's it.
Old Mar 21, 2013 | 04:06 PM
RocNRoll's Avatar
Car: 1988 IROC-Z
Well shoot. If that's the case, is the battery ruined?
Old Mar 21, 2013 | 04:07 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Yes, but if it's a Diehard or Optima, depending on how old it is, you may have a warranty on it.
Steven 86IROC-Z
May 24, 2026 04:52 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
92projectcamaro
Aug 6, 2015 01:20 PM
