can stock valve srpings handle .488 lift?
Old Mar 22, 2013 | 05:36 PM
87fbodyy's Avatar
Car: 87 iroc-z
Engine: 355 tpi
Axle/Gears: 4.10
whats up guys, im getting a new cam from summit and im not sure if I should get springs too, do yous think the 993 "made in mexico" heads can handle a .488 lift or no?
thanks , justin
Old Mar 22, 2013 | 05:48 PM
87fbodyy's Avatar
Car: 87 iroc-z
Engine: 355 tpi
Axle/Gears: 4.10
Re: can stock valve srpings handle .488 lift?
http://www.summitracing.com/parts/su...make/Chevrolet
heres a link to the cam
Old Mar 22, 2013 | 10:21 PM
jamesddd678's Avatar
I would suggest http://www.summitracing.com/parts/sum-174001, the seals go right on, no machine work. I just put these in my motor this last weekend it was a piece of cake (first time doin springs) and work great with my .480 lift cam. Your local orileys should have a valve spring compressor you can rent. They have some .5?0 lift springs on the cheap as well. They require your valve guide to be cut. Which is not expensive either. Whats the purpose of the car? Are the heads stock? What pistons? My coworker bought a Blazer with these heads in it and the cam was .514 in spots and 5.02 in others, 4 lobes were near round.
Old Mar 22, 2013 | 10:48 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Stock valve springs are good for scrap metal and paper weights. Dont do it, it will end in heartache, or at least wallet ache.
The Lunati 60103 or Comp xe274 are FAR better cams than that old school piece of crap. Much better street manners and way more power at the same time. The cam is the LAST PLACE you want to cheap out.
Old Mar 23, 2013 | 02:54 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Agreed.
Old Mar 23, 2013 | 08:55 PM
87fbodyy's Avatar
Car: 87 iroc-z
Engine: 355 tpi
Axle/Gears: 4.10
your right , thanks for the advice. just ran into some extra play money so im gonna do it right the first time, probably go with the comp
Old Mar 24, 2013 | 12:12 AM
While your at it might as well get some carbide burrs and do some porting!!
gta90
Sep 15, 2015 04:00 PM
NBrehm
Aug 25, 2015 11:49 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
mustangman65_79
Aug 8, 2015 01:18 AM
