bogging no power
Old Mar 26, 2013 | 11:40 PM
89R/S's Avatar
Car: 1989 camaro rs
Engine: 305 lo3
bogging no power
I have a 89 Camaro l03 305 tbi the problem I am having is that it bogs down under sudden throttle increase and doesn't pull as hard as it should especially after 20mph I cleaned the throttle body and vacuum lines by spraying brake cleaner in them took it for a drive and it had a lot more torque the next day not so much back to diving like a 4 cylinder I am wondering if it could be base timing, electronic advance, egr or egr solenoid it has power down low idles good and drives fine other than the lack of power I mean I can floor it and its like it does nothing with the exception of the day I cleaned the tbi and vacuum lines I am at a loss
Old Mar 27, 2013 | 04:44 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: bogging no power
The first thing is that punctuation is your friend.
Check all your vacuum lines, make sure you don't have a vacuum leak somewhere. Make sure you have the proper fuel pressure (Should be 16-19psi with TBI). Replace your fuel filter and air filter.
Check your timing, make sure it's correct. Should be 6* BTDC or there abouts with the ECM disconnected (Four wire connector coming from the dizzy). Do a tune up, new plugs, plug wires, cap and rotor.
Double check the timing though, my number is from a Carbed car so it may not be entirely accurate for TBI.
Infested
May 22, 2018 11:56 PM
777Shock777
Oct 29, 2015 04:30 PM
someone972
Aug 30, 2015 12:52 AM
Logan Bryant
Aug 27, 2015 11:52 AM
sailtexas186548
Aug 24, 2015 10:11 PM
