89 iroc won't restart
Old Mar 28, 2013 | 05:29 PM
StringRust's Avatar
Car: '89 Camaro Rs/ '87 Z28
Engine: 305 c.i. TBI/ 305 c.i. 4bbl
Transmission: 700r4/T5
Axle/Gears: 3.73 posi/ 3.73 posi
I'm working on an 89 iroc-z that my cousin bought. It had plenty of issues when he bought it. It wouldn't start unless you sprayed starting fluid in the intake but then would stall when it burned up all the fluid. Found out Maf sensor was bad so I replaced it. Now it starts with no problem but runs a little rough. The issue I'm trying to fix now is that if you shut it off and try to restart it it will just crank over but not start unless you let it sit for a while. Computer shows a code 44. O2 sensor lean. I'm thinking a vacuum leak somewhere maybe? Hopefully not a blown head gasket? Any other suggestions?
Old Apr 5, 2013 | 02:09 PM
StringRust's Avatar
Re: 89 iroc won't restart
Old Apr 5, 2013 | 02:26 PM
WorkmanLt1's Avatar
Car: 1995 Trans Am
Engine: 5.7 LT1
Possibly a clogged fuel injector or fuel pump going bad. I would also suspect the O2 as well.
Could be an air leak at the intake manifold, and possibly the throttle body.
Ive even seen some with bad exhaust manifold gaskets, that would run like crap and cut off.
Derick15
Sep 17, 2016 05:28 PM
chazman
Aug 22, 2015 02:01 PM
Bryan F
Aug 18, 2015 02:28 PM
zeitghaist
Aug 18, 2015 07:33 AM
mustangman65_79
Aug 11, 2015 03:17 PM
