Car Stalling (Trouble Codes)
Old Apr 5, 2013 | 03:46 PM
jthomas711's Avatar
So my car has been stalling when idle for the last couple weeks. Recently, the problem has got worse and my car will stall when I'm rolling at slow speeds.
I finally decided to get a ODB1 Scanner and I came back with some codes.
Code 22 Throttle Position Sensor(TPS), signal voltage is low during idle or Fuel Cut off relay circuit open or shorted to ground
Code 23 Manifold air temperature sensor voltage low or high, TPS error, or Mixture Control solenoid open or short circuit problem
Code 43 Electric spark timing circuit-low voltage detected or Electric spark control - circuit problems.
Can anybody give me any tips about what I should do next or more incite into what these codes mean?
Also, I noticed last time that when I unplugged my TPS my car no longer stalled. I figured maybe my TPS was the issue so I got a new one, but when I plugged it in, the stalling resumed.
Wade787b
Sep 29, 2015 01:15 PM
TreDeClaw
Aug 14, 2015 06:58 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
hokis
Aug 9, 2015 03:57 PM
