pushrod guides?
Car: 1990 firbird formula
Engine: 355ci
Transmission: t56 spec3+ cluch
Axle/Gears: 9 bolt disc brake 2.77
pushrod guides?
Can I use self aligning rockers with guides and how tight shoild the pushrod be in tue guide? I tryed to put the pushrods I have in and the drag on the guides pretty good so could I just take a file and open them up a little?
Re: pushrod guides?
No you absolutely CANNOT do that.
Use ONE method or THE OTHER; but not BOTH. Pick one, do away with the other.
No sense in destroying your parts just to preserve a mismatch.
Engine: 355ci
Re: pushrod guides?
Ok so could I take the studs out and take the guide plates off and thred the studs back in or should I just get new rockes?
