O2 Sensor Question
Old Mar 31, 2013 | 09:47 PM
MrPackstin's Avatar
Car: 1989 GTA
Engine: 5.7 w/Paxton
O2 Sensor Question
Just wondering if you unplug an O2 sensor on '89 TPI if a SES light should come on? I tried this and I did not get a light.
Found this and mine appears to be workin:
Old Apr 2, 2013 | 09:15 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: O2 Sensor Question
Yes and no. See the SES is tripped when the ECM detects something that doesn't make sense. In this case, for the ECM to determine the o2 sensor is bad (disconnected) it would have to read less than .2V for no less than 50 seconds AND the car must be in closed loop operation. If you say unplugged the o2 sensor and then started the car the o2 sensor would not immediately throw a code. A code would not be set until the car was in closed loop operation and 50 second duration had passed.
Old Apr 2, 2013 | 09:45 PM
MrPackstin's Avatar
Car: 1989 GTA
I did not meet the criteria you described when I checked the SES, but I did do the propane test in the above video. Thanks for info.
Frozer!!!
Jan 19, 2024 04:55 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Caspar
Jun 19, 2016 11:19 PM
redmaroz
Aug 16, 2015 11:40 PM
squiggy2
Aug 9, 2015 09:30 PM
