The tech article for IAC minimum air.
Old Apr 4, 2013 | 08:07 PM
KitCrusader85's Avatar
Car: 1985 Firebird
Engine: 2.8l
does not specify when to remove the paper clip. ..... before starting engine after IAC is unplugged or leave it in? it doesn't say! probably should look into that so people don't blow up the ECM lol
Just thought a tech article should have been a little more clear. So when do you remove the paper clip. This article is really vague and should be re-written.
https://www.thirdgen.org/tpimod2
Old Apr 4, 2013 | 08:20 PM
Car: 1985 Firebird
Engine: 2.8l
Re: The tech article for IAC minimum air.
I know you remove the paper clip after unplugging the IAC but others may not.....
apie2546
Oct 16, 2016 02:24 PM
jaridjohn
Oct 5, 2015 07:01 AM
thejimsterz28
Sep 30, 2015 08:52 PM
