EVAP delete... kinda
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
Had an idea... Can i take the line off my TB for the evap and will it still work but instead purge out into the atmosphere rather then my thorrle body. Or does it need manifold vacuum via the TB to purge???
Why would I want to?
Just looks cleaner, 1 less hose running to TB
Thoughts?
Thoughts?
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Engine: 5.7 L98
Car: 82 Z28
Transmission: T400
Engine: 5.7 L98
Engine: 4++,350 & 305 CIs
Re: EVAP delete... kinda
It will a little bit but not like it should. It really needs vac to work properly.
I know guys that run a hose from the gastank vent line to the inlet part of the airfilter housing. when the motor is running it just kinda sux vapors in. When its off you'll still get some fumes on a warm day tho.
HoosierinWA
Oct 7, 2015 10:15 AM
