MSD Ready to Run Distributor & Stock Coil Question
Old Apr 8, 2013 | 05:35 PM
jnman's Avatar
Car: 87 Iroc Z Convertible
Engine: 305 LG4
Transmission: 700 R4
Guys, I swapped out the Lg4 for a 350 HO crate motor in my '87 vert. Getting close to firing it up! I did a search and could not find a answer to my question.
The question is about the output on a stock coil. Pink in is switched power, white in is tach. On the output side (of the factory coil) pink is power (+), is the white for the tack only or also considered the negative side of the coil??
MSD shows wiring for the new Ready to Run Distributor (with Blaster II coil).........
Red wire to the positive side of Blaster (will use output side pink)
Orange wire to the negative side of Blaster (can I use the output side white)
Black wire is ground.
Did not want to assume this would work and burn something up!!!!!!
There is not a lot of room under the hood to put the bigger coil, so I would like to keep the stock location. If I can wire as above, I'll replace with the MSD version of stock. If not guess I have to figure out where to put the Blaster coil (pass side inner fender).
THANKS, Jeff<jnman>
I also posted this in the Electrical section seeking an answer.
Old Apr 9, 2013 | 05:38 AM
jnman's Avatar
Engine: 305 LG4
Re: MSD Ready to Run Distributor & Stock Coil Question
Anyone?
Frozer!!!
Jan 19, 2024 04:55 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
jharrison5
Aug 19, 2015 05:53 PM
Thirim
Aug 13, 2015 03:09 PM
