Please help IAC valve
Car: 1986 Chevy Camaro Berlinetta
Engine: 305 V8 5.0 carb.
Transmission: Automatic
Axle/Gears: the kind that came with the car...
Could someone tell me where the Idle Air Control valve is on a
86 camaro berlinetta 305 5.0 V8 automatic trans. is?
My car idles high in park. I have checked for vacuum leaks.
I have replaced PCV valve. But car still idles high in park.
So I need to know where the IAC valve is. Could someone please tell me where this is?
Thanks in advance!
Thanks in advance!
Re: Please help IAC valve
Its carbed, it doesn't have one. Make sure that you have no vacuum leaks, tighten down the carb. It might have a stepper motor holding the throttle open, make sure the fast idle cam on the carb isn't hung up.
ah yes! now that makes sense...thank you very much for the info!
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Also note that if your car has factory a/c and you have the HVAC mode selector in
either the a/c, max, or defrost positions the idle will also be increased.
