Dyno Results
Old Apr 15, 2013 | 10:27 AM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
Dyno Results
Dynoed my vortec headed 383 this weekend. Specs are as follows:
- 383ci
- Compstar 6" h beam's
- Wiseco forged pistons
- 10:1 CR
- Comp hydraulic roller (224/229 duration @ 0.050", 0.598"/.544" lift w/ 1.7 int and 1.6 ex rockers, 110 LSA installed on a 108 intake centerline)
- Production vortec heads with 2.02/1.60 valves, Intake port as cast(other then bowl work to match valve job) minor porting on the exhaust.
- Peformer RPM air gap, no port work other then a bull nose plenum divided
- 1.5" carb spacer, (1" open and a 1/2" nitrous plate)
- AED 750 HP-HO (74's primaries & secondaries, 4.5" PV's)
- MSD pro billet locked out at 36 degree's
- 1 5/8" - 1 3/4" step header
- Moroso 4 vane vac pump pulling roughly 11-12" of vacuum at 6500RPM
The results: 481HP @ 6000rpm 487ft-lbs of TQ @4700 RPM.
Old Apr 15, 2013 | 11:13 AM
AutoRoc's Avatar
Engine: Vortec 4200 Inline 6 PT70 Turbo..
Transmission: 4L65E
Re: Dyno Results
That will get out of its own way! Congrats, i'm sure it was a fun, nail biting experience.
Those are impressive numbers for a cleaned up vortec head aren't they? I've been out of the loop on magazine SBC builds in the last few years.. Haha
Old Apr 15, 2013 | 11:40 AM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Re: Dyno Results
Very decent for near-stock heads and mild CR!
I'm glad to see you made a sensible cam choice to match the rest of the combo
Old Apr 15, 2013 | 12:06 PM
Car: 1979 Malibu
Engine: Blown LSx
Re: Dyno Results
Ive never been one to over cam a engine.
Old Apr 15, 2013 | 12:21 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: Dyno Results
Nearly 500hp on nearly stock Vortec heads. Very good. People choosing Vortecs will be happy to see this. It's also cool to see someone else using vacuum evacuation. Would be interesting to know how much of a gain this provided.
Old Apr 15, 2013 | 12:24 PM
Car: 1979 Malibu
Engine: Blown LSx
Re: Dyno Results
It netted roughly a 4Hp gain, but the ring is just a standard tension 1/16"-1/16"-3/16" mahle, Gains would have been much higher with a ring combo better suited for vacuum like a 0.043"-0.043"-3.00mm low tension ring pack. but when I built the engine I didnt intend on running a vacuum pump.
Old Apr 15, 2013 | 02:00 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Re: Dyno Results
Still the 1/16 rings will be happier down the road with added evacuation. They do pass more gas but also reduce friction. The only down side of the vacuum pump is that it needs to be rebuild about every 5,000miles. Moroso does it for a $125 flat fee including return shipping. I take it that this motor won't be a daily driver so like me, you can handle these things in the off season. Ive thought about having a front cover machined for the pump that takes a sealed ball bearing to increase service life.
Old Apr 15, 2013 | 02:07 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Dyno Results
Surprised to see power go that high with such mild cam and stockish port vortecs. Very solid numbers.
Old Apr 15, 2013 | 02:14 PM
Car: 1979 Malibu
Engine: Blown LSx
Re: Dyno Results
We stock the kit's here and I have rebuilt so many I can do it in the dark.
Old Apr 15, 2013 | 02:18 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Re: Dyno Results
Right on. So you work at the machine shop. Experience building HP small block chevys I'm thinking has more than a little to do with those unusual results.
Old Apr 15, 2013 | 02:34 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: Dyno Results
I see the ultra high intake valve lift. That would help explain the power peaking high. Who says vortec heads dont work with over .550" cams because flow backs up? Lol
Old Apr 15, 2013 | 03:16 PM
Car: 1979 Malibu
Engine: Blown LSx
Re: Dyno Results
Our flow bench begged to differ on that one. These didn't see any significant gains, but didnt fall on there face as everyone always makes it sound like they do. Not bad for a head with a 173 cc intake port. Even though certain member's on this site insist you need a minimum of 195 cc for a 383ci engine.
Old Apr 15, 2013 | 03:37 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: Dyno Results
Yeah perhaps the valve job and bowl worked help stabilize airflow and allowed gains above .500"?
I would be one of those who insist a 383 receives 195cc but usually because rpms are over 6000. Lol Port those heads out some to a larger csa and pour 190's cc and i bet numbers go up. Or atleast has potential for more rpm and power with more cam. Seen a 580 hp 383 with vortecs that poured 190's cc and flowed 280-ish cfm. 2.050 valve. 230 deg hyd roller under .600" lift . Above 6000 rpm 383 needs some airflow. For street, lower rpm range, this combo you have kills! Very solid
Old Apr 15, 2013 | 03:42 PM
Car: 1979 Malibu
Engine: Blown LSx
Re: Dyno Results
I dont reall intend on turning it past 600-6200, I wanted a torque monster and thats what I got. I have already got the ball rolling on the new engine. A local drag radial guy is helping me out with it. I have most of the engine pieces, going to start putting it together this summer. The plan is a 370ci 6.0L, GM LSA heads, Twin magnum 76mm's, A2A, HP EFI. I want to make 1100RWHP. which seem's to be do-able.
Falcon50
Aug 22, 2020 03:26 PM
LT1Formula
Oct 8, 2015 08:34 PM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
gord327
Oct 3, 2015 01:25 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
