BLOWN HEAD GASKET
Old Apr 15, 2013 | 11:11 PM
JAY618's Avatar
Car: 91 CAMARO
Engine: 305 V8
Transmission: AUTOMATIC
BLOWN HEAD GASKET
WHATS GOING ON FELLAS I HAVE A 91 CAMARO V8 5.0 I WANTED TO KNOW HOW DO I GET TO THE HEAD GASKET AND IF I HAVE A BLOWN HEADER WILL IT MAKE MY CAR NOT RUN
THANKS
Old Apr 16, 2013 | 11:43 AM
Beef's Avatar
Car: 89 RS
Engine: Stock L03
Transmission: Stock T5
Axle/Gears: Stock, Too high
Re: BLOWN HEAD GASKET
Drain anti-freeze, bleed fuel pressure, remove induction sys, unhook exhaust manifolds/headers, unhook fuel sys, remove distributor, remove manifold, remove valve covers, remove head bolts, lift off heads, there's a few other things but they should be obvious, its an easy job, but not one someone mechanically disinclined should untake alone, since you have to ask you should probably find someone to help, also figure on it taking a full day to possibly a weekend since you've not done it before. Regardless, buy a manual, there's more torque specs and small steps than anyone will want to share when it goes back together, and you'll be able to handle most things on your own with the knowledge it provides.
If you're asking about a blown headgasket, while its possible the car wouldn't run if one were blown its not very common, usually the engine will smoke allot, consume coolant, and possibly run rough, but run.
3rd gen money
Sep 8, 2015 11:40 PM
earlpote
Aug 28, 2015 10:42 AM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
