Estimated HP and TQ
Old Apr 18, 2013 | 06:16 AM
usc iroc's Avatar
Car: 89 Iroc
Engine: 383
Transmission: 700
Axle/Gears: 4.11
Estimated HP and TQ
Im sure you guys can give me a good estimate on the power of my combo.
383 SBC, HSR intake, 58mm TB, 24#inj, gutted stock MAF and airlids removed, ProComp 200 aluminum heads, Comp 276 roller cam, 1.5 roller rockers, 1 5/8" headers, 700 tranny, 9" w/ 4:11 gears (incase someone wants to through out some time slip estimates , 165 ECM, complete tuning hardware from Moates and TP.
Old Apr 18, 2013 | 11:30 AM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
Re: Estimated HP and TQ
If I had to venture a guess I would say around 450-460hp, roughly the same torque.
Old Apr 18, 2013 | 12:14 PM
heat seeker's Avatar
Car: 89 Formula
Engine: 383 SBC/HSR
What's your compression ratio? What exhaust setup are you running?
Old Apr 18, 2013 | 12:23 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Call Holley, or Comp Cams since you're running their parts and ask them. They'll ask all the right questions and Desk Top Dyno the combo, plus their technical department has some experience with this, and give you a rough estimate. I would say that assuming 10:1 C/R, 450-460HP is about right.
Old Apr 19, 2013 | 07:16 AM
usc iroc's Avatar
Car: 89 Iroc
Engine: 383
Transmission: 700
Axle/Gears: 4.11
At least we are all on the same page. I was shooting for 450 so thats cool. Thanks for the input. Its not a unique combo so I figured someone would have a general idea.
Old Apr 20, 2013 | 07:11 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
One thing that caught my attention is the 24lb injectors. Unless you're running a crazy high pressure fuel system like mine, these injectors are too small at that power level. 30lb much better.
Old Apr 20, 2013 | 10:55 PM
usc iroc's Avatar
Car: 89 Iroc
Engine: 383
Transmission: 700
Axle/Gears: 4.11
Thanks for the tip...no I am running 43psi.
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
skip91
Sep 24, 2015 03:29 PM
ULTM8Z
Sep 16, 2015 09:15 AM
bellez77
Sep 5, 2015 08:39 PM
Trevor K
Jul 12, 2001 01:44 PM
