backfire when shuts off?
Old Apr 20, 2013 | 06:36 PM
chevyv8guy's Avatar
Car: 84 firebird
Engine: 355
Transmission: 700r4 stage 2 shift kit 2500 stall
Axle/Gears: 3.42 posi
ok ill try and get all info i can to help answer my question..
after running/driving my car whenever i shut it off it back fires, the motor is brand new just built by my local machine shop the carb is new from summit(those street strip carbs its a 650. now the car used to be a carb'd 2.8 and is now a 350.Have a new distributor,plugs,cap,and wires
what could cause the back fire or short continue to run for .02 seconds after the key is shut off?
possibly carb not tuned properly? mechanical fuel pump going? timing off?
any info will be great thanks!
Old Apr 20, 2013 | 09:21 PM
Jersey89GTA's Avatar
Car: 90 Iroc Vert
Engine: 5.0L
Re: backfire when shuts off?
Its timing, 9 times out of ten.
Old Apr 21, 2013 | 08:13 AM
chevyv8guy's Avatar
Car: 84 firebird
Engine: 355
all right ill give that a try thanks!
Old Apr 21, 2013 | 09:08 AM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
start with timing. does it have a bigger cam in it? you will probably want to be anywhere between 7-12 degrees BTDC
Old Apr 21, 2013 | 09:14 AM
chevyv8guy's Avatar
Car: 84 firebird
Engine: 355
this is the cam in it http://www.summitracing.com/parts/lun-00010lk
Old Apr 21, 2013 | 09:18 AM
Car: 91 Trans Am
Engine: 355 TPI
you need to be at around 12-15 degrees BTDC
Old Apr 21, 2013 | 09:19 AM
chevyv8guy's Avatar
Car: 84 firebird
Engine: 355
alright ill give that a shot thanks
Gunner242
Dec 25, 2015 04:49 PM
racereese
Oct 3, 2015 03:46 PM
85 Jimmy
Sep 30, 2015 07:56 AM
ironbmt
Sep 27, 2015 06:00 AM
