"CHUMP CHANGE BUILD" 350 $1500 BUDGET
Old Oct 5, 2013 | 03:49 AM
  #51
eblove911's Avatar
Car: 1990 camaro rs "Fuego"
Engine: 350 vortec
Transmission: 700r4with tci lock up
Axle/Gears: 2.78
Re: "CHUMP CHANGE BUILD" 350 $1500 BUDGET
future plans are as follows.....
$400 for 15 yards of red on black Gucci cloth fabric should be enough for the interior((interior on hold til the car is running right)
$170 for hooker 2460 shorty headers....muffler shop charging $300 to button it up with dual exhaust dumping before the tires out the side tucked up very well.
I purchased for $50 I think edelbrock part number #8032 vortec universal bracket for throttle cable, tv kickdown, and cruise. Non vortec model is #8031. I tried the Mr. Gasket type from Oreilly's and it was too flexible and bent during mock up at WOT.
I also purchased a ws6 hood scoop fiberglass for $170 since the air cleaner will not fit so far. Like I said I have either O'reillys or ebay as my parts stores sadly.
Old Oct 5, 2013 | 04:01 AM
  #52
eblove911's Avatar
Engine: 350 vortec
Axle/Gears: 2.78
The tci external harness is easier to install if you do not try to mount it onto the side of the transmission, but instead on the inside of the drivers fender there is a set of relays,...look on the fender there is a single bolt that you can mount the ground to and bolt the harness to the fender wall easily. What I did was extend the wires with the same gauge wire ran one to the inside the green one which I will hook up to a momentary flush mount button $8 each on ebay also look for vandal switch in the search bar. Mine, I will be trying to make a panel in the ashtray to hide the buttons as I do not smoke. The black wire was ran to the harness and the red power I ran to the battery directly tucked along the underside of the fenders and firewall to the positive side of the battery.
This car will be a tribute car now painted all black with red candy true flames engulfing the front and feathering to a tip to the rear and the top coat of the red candy will have red luminous paint pearl added so at night the flames will flicker and glow. 40 mins. I have yet to buy the luminous though. Like I said a lot is happening but I have plans now.
Old Oct 5, 2013 | 04:06 AM
  #53
eblove911's Avatar
Engine: 350 vortec
Axle/Gears: 2.78
I need to get a steering column as this one was torn up when I got it lights only work if the highbeams are on and no side markers or blinkers but that is another thread. was giving updates now back to the subject the motor....
I Have no idea where it will be rated though??? I tried the dyno2000 program and put in the info 10.5:1 compression with flat tops I think, xe258hr cam, int .480 ext .480 lift , vortec 906 heads, vortec edelbrock performer rpm intake, edelbrock 750 carb with electric choke,.... It gave me a hp rating of over 400 hp at the flywheel, and no I did not delete the ac I see no point in having a daily driver that is cool but it doesn't keep u cool unless the windows are down.... Not cool. I will get the hp back when I put the exhaust on.
Old Oct 5, 2013 | 04:16 AM
  #54
eblove911's Avatar
Engine: 350 vortec
Axle/Gears: 2.78
I don't know what else to put until I find a way to put pictures of the motor?????
So to tally it up again here's all I got motor wise
Hei Distributor fhe intake from ebay 65k coil $50
vortec motor minus the intake and tbi for me $300 typically at a junkyard though $500
vortec performer rpm intake $200 ebay
tci lock up kit $90 Summit racing
Mallory 4309 fuel pressure regulator $110 ebay
morso drop base air cleaner $110 or ebay may have one?? I haven't purchased one yet
Hooker 2460 shorty headers $170 ebay with gaskets
*****If you want to bump up the hp the xe258hr cam is $250 on ebay just the cam***
Old Oct 5, 2013 | 09:28 AM
  #55
DiabolicalRS's Avatar
Car: '90 Camaro
Engine: 305 tbi
Axle/Gears: 9 bolt posi 373
make a photobucket account and from there upload your pics and copy the url and paste in the reply box.
Old Apr 20, 2026 | 08:47 AM
  #56
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Nice to meet you at work today eblove911
Old Apr 20, 2026 | 10:12 AM
  #57
eblove911's Avatar
Engine: 350 vortec
Axle/Gears: 2.78
You too now that I have someone into thirdgens I can motivate myself to get back to mine
Shane4524
Oct 30, 2011 09:01 PM
whiteg19
Jul 13, 2009 10:53 AM
hereinmissoula
Mar 26, 2009 03:25 PM
Nitsuj86Iroc
Nov 5, 2005 10:15 AM
JRoy91RS
Aug 18, 2001 11:58 PM
