Shifter problems
Old Apr 22, 2013 | 08:27 PM
transamman83's Avatar
Car: 83 Trans am, and 91 Camaro
Engine: both have a 305.. For now
Shifter problems
So I got the engine and tranny installed and buttoned up today. I went to start and move the car and the shifter wouldn't move. The tranny will shift through all gears fine if i unhook the cable and move it by hand so its not the tranny. Any ideas. After looking in the console I saw this part laying in the bottom.
Old Apr 23, 2013 | 09:46 AM
Re: Shifter problems
After messing around I have more to add. If I removed the shifter cable from the shifter I have the same problem. But if I disconnect the other cable that is attached to the shifter it will move fine. What is this other cable? Is it like a park n safety cable or something? What would cause it to be bad all of a sudden? What are the ramifications of just disconnecting it?
Old Apr 23, 2013 | 05:53 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Yes.
Wearing out?
Did you do anything with the steering column? Ignition tumbler?
It will shift out of park with the steering wheel locked by the ignition being in the locked position.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
middian
Sep 5, 2015 01:42 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
neekolzun
Aug 24, 2015 04:59 PM
