broken bolts
Car: 1982 Z28
Engine: 388 SBC
Transmission: TH350 Lockup
Re: broken bolts
That's an easy one, if you have access to a welder, weld a nut onto it, and loosen it off, it may take a few times, but it will come off. or get a bolt extractor, they make them that will fit over the stud and turn it out. Shouldn't have a problem
Car: 1989 camaro iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 323
Re: broken bolts
Does auto zone or any of the parts store sell bolt extractor that go on your3/ 8 ratchet?because i have not see them in the store.
Car: 1982 Z28
Engine: 388 SBC
Re: broken bolts
Auotzone should, or napa or one of the parts houses, they should have them, it just goes over the top of the stud, and it'll turn it out (or should) welder is the best way if you have access to one...
Car: 1982 Z28
Engine: 388 SBC
Re: broken bolts
Something like this, may even work http://www.sears.com/shc/s/p_10153_1...30-163239586-2
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: broken bolts
I hate to bring the ants to your picnic but there isn't enough of the bolt left for any of the stud extractors I have, and I have them all. The welder is your only real hope of extracting that bolt. Or you can get out your drill and try your best to drill it out. I do them all here, even the ones I don't break. I have pretty solid success using cobalt bits, including left handed drills that will sometimes spin the bolt out. The trouble in your case is that the bolt is probably corroded to the aluminum and isn't going to want to break loose. That's where the welding trick is good because it heats up the bolt and helps break it loose. A torch also works when you have something to grab onto. What I suspect will happen if you use a stud extracter on what's left of that bolt is you will spin off the end of it and then end up having to cut it back down flat so that you can get centered on it to drill it. One thing you can't use enough of on old rusty stuff is PB Blaster, or any other good penetrating oil.
Engine: 350 tpi
Transmission: auto
Axle/Gears: 323
Re: broken bolts
All i wanting to do was put a new temostat in and flush out the system . Now i get to drill out a bolt . Is what it is .
Car: 89 RS
Engine: Stock L03
Transmission: Stock T5
Axle/Gears: Stock, Too high
Re: broken bolts
I've removed allot of broken bolts, that one is likely seized, heat it, real hot and let it cool, or heat around it, the nut trick would be ideal, but if it isn't an option I'd certainly try one of these http://www.irwin.com/tools/screw-bol...olt-extractors I've seen them at AZ, Advance, and Napa, I have the same thing Matco or Mac branded. It might work, you're not out much if it doesn't, only then would I l.h. drill since it also may work, and then use a e-z out or other spline type extractor, I have most if not all, and prefer this type . Little advise absolutely do not break the extractor off in the bolt, you won't likely be drilling it out without trashing the manifold.
Engine: 350 tpi
Transmission: auto
Axle/Gears: 323
Re: broken bolts
I use work in a cylinder heads shop when i was younger . Have done it a ton of time but is is easy when they are not on the car. i will give it another try tomorrow. thanks for the input . i will tell you when i get the stud out.
Car: 87 IROC Z28
Engine: 355 cid TPI
Re: broken bolts
"Little advise absolutely do not break the extractor off in the bolt, you won't likely be drilling it out without trashing the manifold.[/quote]"
That is hell. The extractors are harder than the bolt and dull even the cobalt bits. I keep a carbide bit in my drawer just for those times. It drills like crap but it will chew through just about anything.
Re: broken bolts
Grind or file the top of the stud flat. Center punch EXACTLY in the center, real deep. Drill into it with a small bit (1/8" or so to start), then progressively larger ones. With luck it should give up the fight at about 5/16".
Heli-coil the threads, which are almost certainly destroyed, just like everybody else's. Use stainless steel bolts when you put it back together.
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
Re: broken bolts
+1 on welding a nut on there
Engine: 350 tpi
Transmission: auto
Axle/Gears: 323
Re: broken bolts
I got the bolt out using some heat and this stud remover from auto zone work great. this a of pic of the kit
Car: 87 IROC Z28
Engine: 355 cid TPI
Re: broken bolts
Awesome! I have that set. Mine's Matco but same thing. I thought from your photo that there wasn't enough bolt left for that extractor to grip. Glad I was wrong.
Car: 1982 Z28
Engine: 388 SBC
Re: broken bolts
Glad you got it out, I had one of those grade 8 studs break off flush on my intake, the distributor hold down. Talk about cussing that thing like a dog.....
Car: 1986 Pontiac Trans Am
Engine: 5.0
Re: broken bolts
if you are good at tig welding my buddy came up with an idea of tig welding a new head right smack dab in the center of broken stud and just turning it out. it requires precise aim and concentration, but worked for the most part in the past. every time i had one they never got me down. steel bolts in aluminum never play well with each other
opps lol guess im a little late for this one...ohh well whatever gets the job done. 2 thumbs up for "tcrisp"
UltRoadWarrior9
Sep 2, 2015 08:24 PM
