Good deal?
Old Apr 28, 2013 | 08:55 AM
hjsmith00843's Avatar
Good deal?
Won this auction on ebay and it is local so I can pick it up and save $30 shipping on it. Can anyone tell me if that carb work for up to 300 HP?
http://www.ebay.com/itm/Performer-Rpm-Intake-And-Holly-Carb-/130890918211?_trksid=p2047675.l2557&ssPageName=STRK%3AMEWAX%3AIT&nma=true&si=XWYVk%252BxA4Ztsms%252Fwn5ASPdB5Oyk%253D&orig_cvip=true&rt=nc
Old Apr 28, 2013 | 09:29 AM
Pat Hall's Avatar
Re: Good deal?
Yeah that setup should easily be able to give you 300 HP with the right cam and other engine components. I noticed the auction has ended. Did you end up buying it then?
Old Apr 28, 2013 | 09:42 AM
Re: Good deal?
yes i won it. Going this week to pick it up. Can you tell what carb that is by looking at it?
Old Apr 28, 2013 | 09:44 AM
Pat Hall's Avatar
Re: Good deal?
Looks like a universal 600 cfm, vacuum secondary, 1850 model Holley to me. They work great on milder SBC's. 300 HP should be possible with that intake combo with the right cam, heads, etc.
Old Apr 28, 2013 | 09:56 AM
Re: Good deal?
The heads on the car are world performer torquer 305's. Smog headers (will change to long tubes shortly) Fuller roller 1.5 rockers. unsure with the camshaft. What cam will work well with that setup.
Old Apr 28, 2013 | 10:04 AM
Pat Hall's Avatar
Re: Good deal?
Just guessing here, but I'm assuming you're running a flat tappet camshaft right, and not the factory roller cam? Basically 86 and older motors use the flat tappet cams, and 87-up uses the factory roller cams. If you do have a flat tappet motor, the old Comp Cams 280 Magnum is a good choice. Another good choice that a lot of guys have been using the last few years or so is the Lunati Voodoo series cams. One of these cams should get you close to your 300 HP goal and work well with that intake/carb.
Old Apr 28, 2013 | 10:10 AM
Re: Good deal?
Unsure on the cam. Will see if it is roller or not when I do the intake change. will change the cam at a later date along with a new timing chain and damper.
Old Apr 28, 2013 | 10:26 AM
Pat Hall's Avatar
Re: Good deal?
If you end up needing a roller cam, the GM ZZ4 crate motor cam can usually be found pretty cheap. Or maybe this one: http://www.summitracing.com/parts/cc...make/chevrolet, or a bit milder with this one: http://www.summitracing.com/parts/cc...make/chevrolet
Old Apr 28, 2013 | 12:31 PM
Re: Good deal?
I think it has the ZZ4 cam in it now.
hectre13
Dec 11, 2023 08:14 AM
InfinityShade
Aug 22, 2015 08:00 PM
Hello, Michael
Aug 20, 2015 03:19 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
ChevyZ71
Aug 13, 2015 07:30 AM
